amichalski81 Posted January 23, 2013 Share Posted January 23, 2013 can i turn OFF the auto controls? everytime i get into the car on these cold days in NJ and go to turn up fan speed it says the unit is on A/C. why do i want A/C in 20degree weather? is there a way to turn off ALL auto controls? and just have it manual to the way i want it to be? ............A/C in the winter.... Link to comment Share on other sites More sharing options...
dirtyboy Posted January 25, 2013 Share Posted January 25, 2013 The A/C is like a de-humidifier. It is used to keep the air dry so that there is no fogging of the windows. Every car that has A/C turns it on for the defrost cycle. IMO, let the system do what it's programmed for. Link to comment Share on other sites More sharing options...
DrD123 Posted January 28, 2013 Share Posted January 28, 2013 You can sort of do that - if you hit the AC button, it will turn off (and the display will go from "full auto" to "auto" then if you set the mode to where you want it, it will remain fixed. Same deal with the fan speed. It will stay that way until you hit the "off" button, then it's back to full auto. I often turn off the AC here as it's not needed to defog the windows most of the time since it's pretty dry in NM. Link to comment Share on other sites More sharing options...
