Truukk Posted August 6, 2012 Share Posted August 6, 2012 I was looking to paint my wheels in bronze, Before I order..How many cans would I probably need. And Would I need anything else..Like a scuff pad or the primer paint? The rims are like a alloy/metal. Any help would be greatly appreciated http://i49.tinypic.com/2e5ntb5.jpg Dont mind the desktop stuff. I couldnt find the pic in my folders so I had to printscreen my car. Link to comment Share on other sites More sharing options...
Karumba Posted August 6, 2012 Share Posted August 6, 2012 Are you planning to just spray paint over the finish as it stands right now? Basically outline the process I've done prior: 1) Thorough clean -- think brake fluid cleaner/degreaser 2) Sanding, sanding, and more sanding -- usually started with 320 grit, may go heavier and then tapered off to remove lines 3) Clean again (not as potent - but still enough to clear away sanded debris) 4) Mask off (if needed) 5) Primer sandable paint (fill in blemishes and give it a base to adhere) - then dry 6) Verify/resand if needed (and respray) 8) Paint then dry 9) Clear coat As for how many cans you'd need - depends on the size truly. I'd lean and say two primers, two-three paints, and one clear Anyways .. DIY videos might be cheesy, but research helps rimpainter.com [ame=http://www.youtube.com/watch?v=q5eK5OnHfqA]How to Paint Your Wheels / Rims - YouTube[/ame] Pictures of my rides; 2001 Honda Civic LX 4dr old whip[/url] Current Wagon Link to comment Share on other sites More sharing options...
underground000 Posted August 6, 2012 Share Posted August 6, 2012 When I did it (wayyy back then) I used 1 can for 2 wheels, and 1 can of clear for 2 wheels make sure you clean them really really good, and sand them I very quickly got tired of the good and went to something more sleeper:lol: http://i596.photobucket.com/albums/tt49/underground000/08%20LGT%20DGM/CIMG1669.jpg http://i596.photobucket.com/albums/tt49/underground000/08%20LGT%20DGM/CIMG1658.jpg http://i596.photobucket.com/albums/tt49/underground000/2a25988f.jpg?t=1339377847 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Truukk Posted August 6, 2012 Author Share Posted August 6, 2012 awesome, that info helped alot. ill post pics when I get it done! Link to comment Share on other sites More sharing options...
