CypherMax Posted August 29, 2008 Share Posted August 29, 2008 I'm going stage 2 on Saturday with Cobb dp and grimmspeed up. When I am going to Flash stage 2 on the accessport should I reset the ecu? If so should i do it before or after the flash? Also do I have to but a resistor in the EGT sensor since my up pipe deletes that or does the accessport ignore this code? And finally I own a mac and I have never updated my ap cuz the software won't work on macs. I have the newer version of the ap I think my current software level is 1.1.4? Should I try and update it before I reflash? Or is it not important? Thanks guys! Link to comment Share on other sites More sharing options...
caramall2 Posted August 29, 2008 Share Posted August 29, 2008 - Reset: From what I understand, when you install BASE maps, you've reset everything--so just flash your base stage 2 map. Changing "real time" maps doesn't reset the ECU (but of course if you need to, can just reset it using the AP). Not sure on the other questions...I think the Cobb maps take care of the EGT issue but not positive. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 30, 2008 Share Posted August 30, 2008 CEL's can be disabled by the tuner with the street tuner software. I would make sure you have the most up to date firmware installed on the the AP itself. Link to comment Share on other sites More sharing options...
