mattg Posted November 17, 2005 Share Posted November 17, 2005 about a week ago i suddenly started hearing a really annoying rattle coming from my exhaust at low rpm's. when the car is idling and i rev it a little, as it passes through the 1000-1500 rpm range it sounds like i have a rod knocking or my car is a diesel, especially as the rpm's come down. i listened as well as i could and it seemed to be coming from around the resinator. so yesterday, i finally got it up on a lift to check it out. sure enough it is the resinator, but not from the resinator hitting something or a rock stuck in a heat shield. the noise is coming from inside the resinator. i guess the resinator doesn't like my new boost levels (peak @ 18.4) because it seems like something let go inside of it. or maybe i just got a bad one. anyways, it has to go, and hopefully that will happen today. i'm going to have a straight pipe welded in place of it, since i doubt subaru will warranty it because of the new hardware that is residing just upstream. i'll let you guys know how it goes. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 17, 2005 Share Posted November 17, 2005 lemme guess.... catless up and new dp with no cat. (total of 1 cat instead of stock 3) it's backfiring, mine does it too. Most people with catless up's get this too. i bet you'll still get the noise with the straight pipe, just might move around My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
styx0r Posted November 17, 2005 Share Posted November 17, 2005 Backfiring and rattling sound a bit different in my mind. There's no way mattg would be getting rapid backfiring around 1000-1500rpm. The occasional pop, crackle, etc I can understand... Link to comment Share on other sites More sharing options...
BadAndy Posted November 17, 2005 Share Posted November 17, 2005 Possibly blew out some of the 3rd into the resonator? Link to comment Share on other sites More sharing options...
mattg Posted November 17, 2005 Author Share Posted November 17, 2005 i'm totally catless. and this noise isn't popping or backfiring, as i can hear that as well when i rev it up higher and let it rev down. my buddy at the exhaust shop confirmed it. there is metal on metal vibration coming from inside the resinator, and the sound is embarrassingly loud at low RPM's. res. comes out tomorrow, and a piece of sleeved stainless pipe is going in it's place. can't wait, the sound is driving me nuts. Link to comment Share on other sites More sharing options...
PhilT Posted November 17, 2005 Share Posted November 17, 2005 I have a similar sound when i let of the gas at idle, and i have no cats and no resonator. It's the extra rich mixture causing slight backfiring. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted November 17, 2005 Share Posted November 17, 2005 Well go ahead and replace it. But when you still get the noise, don't say we didn't tell you. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted November 17, 2005 Share Posted November 17, 2005 Does it sound like this : http://media.putfile.com/Exhaust5142 There's alot of echo as the car was in the garage at the time, but it's backfiring. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
sandwood Posted November 17, 2005 Share Posted November 17, 2005 i gotta rattle and no resonator. hmm. but mine happens over pavement irregularities at low speeds, so... getting out of the legacy game Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 17, 2005 Share Posted November 17, 2005 What's that heavy, useless thing still doing in your exhaust Matt? Link to comment Share on other sites More sharing options...
jarrod Posted November 17, 2005 Share Posted November 17, 2005 ewww i have this noise..i have stock exhaust..sounds somethink like the motor knocking....let me know what you do to fix this...i could have sworn the noise was coming from the engine bay. Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2005 Author Share Posted November 18, 2005 Well go ahead and replace it. But when you still get the noise, don't say we didn't tell you. well, go ahead and take me for an idiot. i'll post a sound clip to help you comprehend what the problem is. there is a metal on metal rattle coming from inside the resinator. this has been confirmed by a couple of subaru experts as well as the best custom exhaust shop that i know of. it's not exhaust popping or backfire. Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2005 Author Share Posted November 18, 2005 What's that heavy, useless thing still doing in your exhaust Matt? it's on the way out. losing weight and gaining some rumble, for teh win. Link to comment Share on other sites More sharing options...
impostor Posted November 18, 2005 Share Posted November 18, 2005 I had this similar rattle. It almost sounded like rod knock or the timing belt tensioner except it came from the back of the car. It turned out to be coming from the mufflers. Subaru is aware of the issue. In the last Tech Tips newsletter, there was an article that said they examined an STi muffler and discovered that a baffle had broken loose. Jim Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2005 Author Share Posted November 18, 2005 that's the same problem i have, but it's a baffle in the resinator that has broken loose. http://media.putfile.com/rattle55 Link to comment Share on other sites More sharing options...
BadAndy Posted November 18, 2005 Share Posted November 18, 2005 Yep...something loose in the exhaust. Link to comment Share on other sites More sharing options...
jarrod Posted November 18, 2005 Share Posted November 18, 2005 Mine does it really bad when you start the car sometimes...and WOT you get an exhaust smell in the car Link to comment Share on other sites More sharing options...
wrx2blackGT Posted November 18, 2005 Share Posted November 18, 2005 Mine does this as well and im totally catless as well, BUT mine only does it when its cold, as it warms up it goes away. But DEF post some results on the exhaust note after you take out the resonator i want to do it as well, i just dont want it to be too loud. Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2005 Author Share Posted November 18, 2005 that's the same problem i have, but it's a baffle in the resinator that has broken loose. http://media.putfile.com/rattle55 so, does anyone still think that sound is exhaust backfiring or popping? Link to comment Share on other sites More sharing options...
wrx2blackGT Posted November 18, 2005 Share Posted November 18, 2005 as long as your sound in the same as mine i say no way. Link to comment Share on other sites More sharing options...
jarrod Posted November 18, 2005 Share Posted November 18, 2005 yea this is 100% for sure not backfiring Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2005 Author Share Posted November 18, 2005 i just dropped her off for a resinator delete. Link to comment Share on other sites More sharing options...
styx0r Posted November 18, 2005 Share Posted November 18, 2005 i just dropped her off for a resinator delete. Good choice. If you can, inspect the resinator post-delete. Take pics for breakage evidence.... Link to comment Share on other sites More sharing options...
wrx2blackGT Posted November 18, 2005 Share Posted November 18, 2005 POST A SOUND CLIP!!!!!! cant wait to hear it! do you have to stock mufflers still? best of luck Link to comment Share on other sites More sharing options...
PhilT Posted November 18, 2005 Share Posted November 18, 2005 POST A SOUND CLIP!!!!!! cant wait to hear it! do you have to stock mufflers still? best of luck Post #8 has a soundclip of stock mufflers with the resonator removed. Catless UP & DP though. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
