EDO Performance Posted November 3, 2011 Share Posted November 3, 2011 http://img268.imageshack.us/img268/3391/motullogoredsmall.jpg All prices listed are for 05+ Legacy GT 30,000/90,000 Mileage Service $380 · Oil change w/ MOTUL 8100 Full Synthetic Engine Oil 5w30/40 and OEM Filter · Manual Transmission fluid replaced with MOTUL 75W-90 Full Synthetic Gear 300 Oil · Automatic transmission fluid replaced with MOTUL Dexron III Technosynthese ATF and ATF Filter Replaced with OEM Subaru Filter + $75 · Rear differential fluid replaced with MOTUL 90PA LSD Oil · Coolant replaced with MOTUL Inugel Expert Ultra Hybrid Coolant · Brake fluid replaced with Motul DOT 5.1 Brake Fluid · Air Filter Replaced with OEM Air Cleaner Filter · Tire Rotation and Inspection · Full body inspection Recommend Add-ons o Zero/Sports Drain plug - $15 o MOTUL Engine System Clean (Engine Oil Treatment) - $18 o Zero/sports Air Conditioner Carbon Filter - $75 o OEM Air Conditioner Filter - $50 o MOTUL RBF 600 Racing Brake Fluid DOT4 - $10 o Bosch Micro Edge Wiper Blades - $20 o Engine Compression Test - $70 60,000/120,000 Mileage Service $520 · Oil change w/ MOTUL 8100 Full Synthetic Engine Oil 5w30/40 and OEM Filter · Manual Transmission fluid replaced with MOTUL 75W-90 Full Synthetic Gear 300 Oil · Automatic transmission fluid replaced with MOTUL Dexron III Technosynthese ATF and ATF Filter Replaced with OEM Subaru Filter + $75 · Rear differential fluid replaced with MOTUL 90PA LSD Oil · Coolant replaced with MOTUL Inugel Expert Ultra Hybrid Coolant · Brake fluid replaced with Motul DOT 5.1 Brake Fluid · Spark Plugs replaced w/ NGK Indium Spark Plugs · Air Filter Replaced with OEM Air Cleaner Filter · Tire Rotation and Inspection · Full body inspection Recommend Add-ons o Zero/Sports Drain plug - $15 o MOTUL Engine System Clean (Engine Oil Treatment) - $18 o OEM Air Conditioner Filter - $50 o MOTUL RBF 600 Racing Brake Fluid DOT4 - $10 o Bosch Micro Edge Wiper Blades - $20 o Engine Compression Test - $50 Timing belt Replacement $750 · Gates Belt (Power Enterprises Kevlar Belt + $150) · All Idler Pulleys · Tensioner · Water Pump · MOTUL Inugel Expert Ultra Hybrid Coolant · Full body inspection Recommend Add-ons o Tomioka Timing belt guide - $50 o Alternator belt- $25 o AC Belt - $25 o OEM Thermostat - $30 o Zero/sports Thermostat- $75 Clutch Replacement $650 · OEM Clutch Kit · Flywheel resurface · Motul Gear 300 · MOTUL Inugel Expert Ultra Hybrid Coolant Recommend Add-ons o Rear Diff Service w/ Motul 90pa - $50 Feel Free to give us a call or stop by for all your Subaru needs! Open Monday-Saturday! ________________________________ Call, AIM, or PM any Questions Mention this thread to receive this special pricing! Call Toll Free (714) 602-5741 or PayPal - Service@edoperformance.com Thank you for your business EDO Performance Call: (714) 602-5741 AIM: EDO Sales Email: Service@edoperformance.com __________________ EDO Performance U.S.A. Master Distributor for: Cusco, M7 Japan, Tomioka Racing, Zero Sports, Motul Phone:(714)602-5741 Follow us on: http://t2.gstatic.com/images?q=tbn:WnsmOCuSOUlvmM:http://www.nuigalway.ie/erasmus/images/facebook_logo.jpg http://a3.twimg.com/a/1278960292/images/fronts/logo.pnghttp://shop.edoperformance.com/images/banners/social4.jpg Link to comment Share on other sites More sharing options...
EDO Performance Posted November 17, 2011 Author Share Posted November 17, 2011 bump bump Link to comment Share on other sites More sharing options...
EDO Performance Posted February 4, 2012 Author Share Posted February 4, 2012 bump bump! Link to comment Share on other sites More sharing options...
EDO Performance Posted July 17, 2012 Author Share Posted July 17, 2012 bump bump for opening this saturday! if you need any motul, you can pick up too! Link to comment Share on other sites More sharing options...
axis008 Posted July 17, 2012 Share Posted July 17, 2012 Bump for great people! Had my oil changed by them a few weeks ago. -ben Link to comment Share on other sites More sharing options...
EDO Performance Posted July 18, 2012 Author Share Posted July 18, 2012 FREE Timing belt Guide with Timing Belt Service Link to comment Share on other sites More sharing options...
EDO Performance Posted August 22, 2012 Author Share Posted August 22, 2012 Tons of Motul Available for pick-up Link to comment Share on other sites More sharing options...
