jonnyt88 Posted October 8, 2014 Share Posted October 8, 2014 Car is a 2009 Legacy 2.5i. I had both front wheels off the ground and noticed that the spin in opposite directions even though the car was in P. I'm curious because I figured with the car in P, they wouldn't be able to spin at all? I assume whatever answer would be similar with a 5eat. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 8, 2014 Share Posted October 8, 2014 When the car is in the air, all bets are off. Even with the car in gear a 5mt well turn other wheels when you tighten the lug nuts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jonnyt88 Posted October 8, 2014 Author Share Posted October 8, 2014 When the car is in the air, all bets are off. Even with the car in gear a 5mt well turn other wheels when you tighten the lug nuts. I never noticed that before.. I assume the same would be for a 6mt swap? Is the rear the same? I don't think i ever had the front in the air all at once, but i know I have jacked the entire rear up to swap wheels. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 9, 2014 Share Posted October 9, 2014 I believe there are three differentials in this car so yes, this is normal. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 16, 2014 Share Posted November 16, 2014 your parking pawl is broken.. if you have car in park and and the front wheels turn, something is wrong they should turn slightly and then stop as the pawl stops the gear. OP states he has an auto (4eat). Since the solenoid is not engaged, the rear wheels will turn independently of each other and the front wheels Link to comment Share on other sites More sharing options...
whitetiger Posted November 17, 2014 Share Posted November 17, 2014 ^no its not. the 4eat has an open front diff. When park is engaged, that locks the ring and pinion to the front diff. the wheels are still free to spin in opposite dirtections since the spider gears are not locked. if you try to spin both forward, you wont be able to. learn how an open diff works. Link to comment Share on other sites More sharing options...
discojon Posted November 17, 2014 Share Posted November 17, 2014 I had a similar issue with my 5eat GT. Had the car on jackstands, all 4 off the ground. First start after rebuild, the wheels started spinning even with the car in park. No clue why, but apparently it's normal for the wheels to spin with the motor running in park and the car elevated. I even spoke with HexMods about it as I thought my VB might have been damaged during the upgrade. Everything works as intended when the car is on the ground.... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 17, 2014 Share Posted November 17, 2014 ^no its not. the 4eat has an open front diff. When park is engaged, that locks the ring and pinion to the front diff. the wheels are still free to spin in opposite dirtections since the spider gears are not locked. if you try to spin both forward, you wont be able to. learn how an open diff works. Wow talk about being a smart ass, do you actually have any friends in life or are you just a hermit living in your mom's basement? I just got done working on my car (a 4eat) and when I jacked up my car to do the front stud removal and brakes, the front wheel I was working on would not move more than a smidge and you hear a click. might want to learn what a parking pawl does....it prevents your car from rolling when you put it IN PARK Link to comment Share on other sites More sharing options...
whitetiger Posted November 17, 2014 Share Posted November 17, 2014 I am an ex-subaru mechanic. i know how it works. if both front wheels are in the air and the pawl is engaged, the open front diff will still allow the front wheels to spin in opposite direction of each other even though the ring and pining is locked in place. you probably only had one front wheel off the ground which of course would not allow spin since the other wheel being on the ground locks the spider gears in the diff in place. Im a smart ass because im right. Again, learn how an open differential works. Link to comment Share on other sites More sharing options...
Ozheritage Posted November 29, 2014 Share Posted November 29, 2014 I agree with whitetiger. I am an ex-auto trans specialist. Yes yeuemmaimai with only one wheel on the same axel off the ground you will get what you experienced. This is the same for any auto trans car with open diff. Link to comment Share on other sites More sharing options...
discojon Posted December 6, 2014 Share Posted December 6, 2014 My car, just taken today. The cel and flashing cruise are cause the rear wheels are spinning and front aren't. http:// Legacy GT wheel spin in park Link to comment Share on other sites More sharing options...
dahoseman Posted December 7, 2014 Share Posted December 7, 2014 I get the impression that someone in here comes from NASIOC forums Link to comment Share on other sites More sharing options...
