MAP Posted May 25, 2013 Share Posted May 25, 2013 I've read every so often about LGTs experiencing ring land failures and want to get an idea whether this is something generally isolated to engines running higher boost pressures than stock. Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted May 25, 2013 Share Posted May 25, 2013 This is going to be a flawed poll. Most people that join a forum are enthusiasts and are much more likely to modify their car. I'm willing to bet most on LGT.com run higher than stock boost. If you could get a poll of the general public outside of the forums that just bought a 'family car' and never modified anything, that would get a more accurate account. I had a ring land failure with #2 and #4 at stock boost, however that was within 3k miles of ownership and I highly suspect the car was running higher boost with previous owner(s). Since I don't know for sure I will abstain from voting. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 25, 2013 Share Posted May 25, 2013 I was at higher boost pressure when I discovered my ring land crack. But just read through a bunch of threads on Nasioc of all their new stock sti's cracking ring-lands. Link to comment Share on other sites More sharing options...
MAP Posted May 25, 2013 Author Share Posted May 25, 2013 Do sti engines use forged pistons? If so thats scary, a definite material or process problem.... Link to comment Share on other sites More sharing options...
lee07 Posted May 25, 2013 Share Posted May 25, 2013 Don't think it matters, but I had burned valves when it was stock which is the main reason of me going E85 Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 25, 2013 Share Posted May 25, 2013 IMO from what I read & heard, the issues with the valves & pistons is with OEM stock tune &\or the tune itself. The tune is everything in these cars. Subaru like to run lean to help with emissions at idle & part throttle, before enriching up the A/F mixture. When it switch from close loop to open loop. If this is true, this can cause knock & destroy pistons & valves. I'm not a tuner, so "IMO" isn't saying much. It's what I'm leaning too from the info. I have came across. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
MAP Posted May 26, 2013 Author Share Posted May 26, 2013 Mike, So have you put on all those miles on the stock tune? If not, how long have you been running the different tune? Thanks. Link to comment Share on other sites More sharing options...
rob-2 Posted May 26, 2013 Share Posted May 26, 2013 The failure doesn't follow a change in boost spefically. My failure only came about because I started to focus on the condition of the motor. It would keep running for some time otherwise. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 26, 2013 Share Posted May 26, 2013 Mike, So have you put on all those miles on the stock tune? If not, how long have you been running the different tune? Thanks. Stock, 0-30k (Peak boost, 14.2), Cobb stage1-93oct, 30k-174k (Peak boost-16.2) Tuning Alliance Custom stage2+, 174k-See Sig. (Peak boost-18.5). Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
OutbackXT05 Posted May 26, 2013 Share Posted May 26, 2013 Usdm sti's use cast pistons. I believe the 04-05 sti pistons are actually stronger which is what we get in the 05 lgt. At least this is what i was told by fred beans. My oem motor lasted 84k. Stock till 65k stg2 till 84. Replaced it with a 2012 sti block and those pistons broke in 3900 miles. I believe I had a fueling issue then though. Link to comment Share on other sites More sharing options...
