subynooby Posted February 10, 2013 Share Posted February 10, 2013 Im new to the legacy world and Im already in love! eventually I want a baja hood, a black grill, and a spoiler But right now im focused on lowering my baby so? any advice? and how low should I go? any reply would be much appreciated! thanks! Link to comment Share on other sites More sharing options...
Magic Marker Posted February 10, 2013 Share Posted February 10, 2013 Congrats on the car, but I think you should slow down. Jot down what you want to do and prioritize. I'm going to bet as you look around and learn more you're overall goal to the car will change. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
subynooby Posted February 10, 2013 Author Share Posted February 10, 2013 Congrats on the car, but I think you should slow down. Jot down what you want to do and prioritize. I'm going to bet as you look around and learn more you're overall goal to the car will change. youre probably right, i just want to make a it a little more aggressive, and i feel like lowering it would do the trick Link to comment Share on other sites More sharing options...
stoggy Posted February 15, 2013 Share Posted February 15, 2013 Well lowering the car is very easy if you're mechanically inclined. If you want it more aggressive then a set of springs and a rear sway bar with upgraded end links would def do the trick. Just keep in mind what wheel/tire combo you plan on running in the future as that will determine how low you can go. I suggest between +38 and +45 offset rims for an even more aggressive look. It will also handle a lot better due to the wider track. If you got money the throw on the ground you can always skip the springs and go right to air bags. Just keep practicality in mind while you're building her up. Link to comment Share on other sites More sharing options...
Kiyo1990 Posted February 15, 2013 Share Posted February 15, 2013 I agree with stoggy. Sway bar and links will do miracles (based on previous cars). Just brain storm, and check out other builds to see if your direction is what you want to do Link to comment Share on other sites More sharing options...
