Heticor Posted February 2, 2015 Share Posted February 2, 2015 Hi I was driving very slow a suddenly the check engine light come on. I hookup a code reader I good P0021. this data from freeze frame: Fuel 1 Cl Cal Load 33.7% ECT (F) : 194 STFT B1 % -1.6 LTFT B1 % 1.6 MAP (Inch Hg) 19.2 RPM 1661 Speed (MPH) 14 Spark Adv 36.5 IAT (F) 10.4 MAF Lb/min : 2 TPS % 18.8 O2S Loc B1S12, B2S O2S B1 S2 (v) 0.855 O2S B1 % : 0.8 OBD Sup: OBD OBD2 Run time 2492 Command Evp % : 98.4 Fuel Level 62% Evap Vp ( Inch H20): 2.498 Baro (Inch Hg) : 29.5 Ecu Volt (V): 14:16 Load Value % 47.8 EQ ratio 0.987 Rel TPS % 7.5 Ambient F 3.2 TPS B % 35.3 ACC Pedal D % 23.5 % E% 23.5 Command TAC% 7.1 some of this data I know what I mean , but other I don't know. What should Check for? Thanks Link to comment Share on other sites More sharing options...
MrTris Posted February 2, 2015 Share Posted February 2, 2015 When was the last time you changed your oil? Link to comment Share on other sites More sharing options...
Heticor Posted February 2, 2015 Author Share Posted February 2, 2015 The oil was replaced 1,682 Km ago (1,052 Mi), I use Castrol SyntecEedge, and Subaru filter. the car runs well, does not use any oil between changes. Link to comment Share on other sites More sharing options...
Industry Posted February 3, 2015 Share Posted February 3, 2015 I would pull the ocv, clean it and reset the code. See if that takes care of it. Link to comment Share on other sites More sharing options...
Heticor Posted February 5, 2015 Author Share Posted February 5, 2015 could you tell me what side is the bank 2, and what is the best cleaner for this valve Link to comment Share on other sites More sharing options...
MrTris Posted February 5, 2015 Share Posted February 5, 2015 could you tell me what side is the bank 2, and what is the best cleaner for this valve Pull 'em both, douse liberally with Brakekleen then reinstall. Link to comment Share on other sites More sharing options...
Lafta Posted February 5, 2015 Share Posted February 5, 2015 Is this a job anyone can do? If yes, is there a how to link, please? Link to comment Share on other sites More sharing options...
MrTris Posted February 5, 2015 Share Posted February 5, 2015 Is this a job anyone can do? If yes, is there a how to link, please? Yeah, anyone can do this! The OCVs are the two little deals on the outermost edges at the top of each valve cover. Grab a ten and start unbolting them from their brackets. Yes, you'll need to pull kinda hard on 'em, don't be a pussy. Pull straight out, soak in Brakekleen, air dry, then coat liberally in WD40. Installation is reverse of removal. There's no trick to these, they're super easy. Have confidence in yourself! Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 5, 2015 Share Posted February 5, 2015 Actuate the ocv's with a 9v battery whilst cleaning them. Mark what side each ocv came from and swap sides on reinstall to be sure. If cleaning doesn't work, replace one or both with new items Link to comment Share on other sites More sharing options...
Industry Posted February 6, 2015 Share Posted February 6, 2015 On the passenger side I had to bend the mount for the upper coolant tank just a bit to get it out. They are about on par with an oil change as far as difficulty. Link to comment Share on other sites More sharing options...
Heticor Posted February 8, 2015 Author Share Posted February 8, 2015 Well I removed the driver side, with difficulty. The space is very tight and the oil fill is on the way of the valve bolt. But the driver side is impossible to remove without disassemble half of the car. The upper coolant bottle support is blocking the valve. I try to bent the support but there is no enough space. Link to comment Share on other sites More sharing options...
Heticor Posted February 8, 2015 Author Share Posted February 8, 2015 This is the infamous suport Link to comment Share on other sites More sharing options...
apexi Posted February 8, 2015 Share Posted February 8, 2015 Hopefully post #14 in the thread below can help. http://legacygt.com/forums/showthread.php/p0011-code-please-help-217629.html Link to comment Share on other sites More sharing options...
Heticor Posted February 8, 2015 Author Share Posted February 8, 2015 Thanks, however he doesn't have the support that I show in the picture Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 8, 2015 Share Posted February 8, 2015 On the adm ej255, the rhs injector guard can be bent out to the rhs giving clearance to slide out the ocv. The action is like a rifle bolt, pull out rotate down and pull out again iirc (or vice versa) Grab it, bend it sideways, remove breather hoses... iirc we removed a bolt from the turbo coolant tank and rotated it out of the way a little (it was a couple of years ago). Tank is just lifted off the locating post, we removed the short fat bit from the inlet too. The Bracket will bend back and we used a shifting spanner to tweak the angle so it was straight. Link to comment Share on other sites More sharing options...
Industry Posted February 9, 2015 Share Posted February 9, 2015 Also pull the little hose right behind the ocv off the head. I just did one of these and it's worse than my 05, but far from impossible. Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 9, 2015 Share Posted February 9, 2015 On adm ej's, the rhs ocv is usually at fault. No one is absolutely sure if the cause is clogging, wear or something electrical related to interference from the adjacent and mostly unshielded injectors. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2015 Share Posted February 9, 2015 FWIW, Bank 1 is the right side of the engine sitting in the drivers seat. (cylinders 1 & 3) Bank 2 is the left side from sitting in the drivers seat. (cylinders 2&4) 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Heticor Posted February 9, 2015 Author Share Posted February 9, 2015 Max , thanks for the information. ok, it is not impossible, but hard to do it, without bending the support, here the manufacture method. it requires a lot of work. Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 10, 2015 Share Posted February 10, 2015 What support? Are you referring to the injector guard? Link to comment Share on other sites More sharing options...
Heticor Posted February 10, 2015 Author Share Posted February 10, 2015 the support shown in the pictures. Link to comment Share on other sites More sharing options...
Industry Posted February 10, 2015 Share Posted February 10, 2015 Just bend it and then when you are done bend it back. Easy peasy. Link to comment Share on other sites More sharing options...
