JamiSteven Posted April 11, 2014 Share Posted April 11, 2014 SO ive had the car for about three months now and have been addressing minor issues here and there as they arise, and this is next on the list.. My car at high speeds (above 65mph) has a steering wheel wobble that is corrected by somewhat jerking the wheel to the left/right and then straight again... Im thinking some kind of bushing in the control arms is causing this? Or possibly wheel bearing? No high pitched noises coming from the bearings though... At first I thought it was a bent rim until I realized the issue dissapears for a while after swerving around a bit. Brake rotors/pads/lines are all new at least in the front.. Thanks in advance. Link to comment Share on other sites More sharing options...
outahere Posted April 12, 2014 Share Posted April 12, 2014 Frozen piston in the caliper? Frozen caliper guide pin? Rear bushing on the control arm? Bad ball joint? Link to comment Share on other sites More sharing options...
