OBXTrunner Posted February 23, 2015 Share Posted February 23, 2015 So i been lurking for awhile and decided to finally make a thread for my 05 OBXT build, last January i blew a rod bearing and swapped in a used longblock, but this January lost compression in cylinder #4 (pretty sure burnt valve) anyways i have a ej255 short block i have completely stripped down and ready to go to hot tank/machine shop. But what im looking for help with is what parts i should go with for the build, would like to be making a steady 350hp... am i crazy? maybe but id like to put together a parts list... now im not going to say what parts/brands i have in mind yet because i would like to get your opinion on what i should be using in the build, everything from internals forged rods/pistons stock crank?, exhaust, inter-cooler (FMIC OR TMIC) any other upgrades i should or have to make? I want this to be a somewhat reliable build (as reliable as you get with a subaru) Thanks in advance for all the help, and let this be a interesting and fun build that in the end will put out decent numbers on the dyno Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 And heres the car behind the build Link to comment Share on other sites More sharing options...
monsterface Posted February 23, 2015 Share Posted February 23, 2015 Are you shooting for 350 wheel or crank horsepower? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 23, 2015 Moderators Share Posted February 23, 2015 Hopefully you have a better idea of what your build will look like than you are letting on...? If not, a reliable 350 to the wheels is a tall order. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted February 23, 2015 Share Posted February 23, 2015 I am assuming you want a true reading 350hp to the wheels. This is what I "want" to do to my car, but never will (probably) Built engine - Forged Pistons / King bearings Dom1.5xtr KillerB holy header ETS FMIC / some BPV downpipe EBCs Clutch that can support it Fuel injectors Fuel pump KillerB pan/pick-up/baffle Infamous Performance and Tuning / Delicious tuning E85 flexfuel kit (this will probably up the power 80-100 over the above set-up) Random other parts LegacyGT brakes / decent pads (needs stop to match your go) Transmission STI / SPEC B 6spd for when your 5spd brakes. I know I am missing a lot, but there are a lot of little parts to think about here. My OBXT build Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 Yeah ive got a decent idea, but im still new to the subaru game, heres what ive been thinking as far as parts so far: Brand new stock crank from Subaru Mahle 4032 piston Manley H beam forged rods Full acl race bearings Arp head studs Aftermarket crank pulley v3 AP Fuel: DW25 fuel pump Injector dynamics 1000 injectors Turbo: Now im leaning towards a tomioka 20g turbo because i know where i can get one fairly cheep brand new I was originally thinking of going with a AVO TMIC but now im leaning towards a FMIC due to bigger turbo needing more cooling. So thats what i am thinking for a parts list so far but im looking for more input on what else i should be adding/changing Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 23, 2015 Moderators Share Posted February 23, 2015 If you stick with a TMIC, go with either a process west (hard to find) or a grimmspeed. If you want to go FMIC, look at the one that SBT is selling on the forum here! OB2.5XT has a fairly complete starting list. Build components for the motor probably aren't as important as who is actually building it. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 And LGT brakes, struts, rear upper control arms and bump stops are also in the future as i want it lower but still functional, but right now im trying to focus on drivetrain, ive thought about the 6spd swap but that an expensive and big decision i havnt decided on yet Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 Ive actually been thinking about the FMIC that SBT has, i really like that setup alot, and looks like one of the best FMIC setups out there Link to comment Share on other sites More sharing options...
700watts Posted February 23, 2015 Share Posted February 23, 2015 Sounds like you're on the right track.....on e85 you'll be able to hold 350 all day. Maybe racer-x FMIC if it fits "it should" as I'm running the same thing. The only thing I see missing is an intake....it's not necessary for your build but, it'll make running the IC piping a lot easier. You'll also be needing a high flow cat.... I would also suggest a tuner local to your area if possible....e-tunes work but personal tunes by a good tuner are better. Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 Im actually not looking to run E85... probably just because of lack of knowledge of it (really need to educate myself more on E85) but yeah i also have to decide on an intake, any ideas? but im probably going to be running a High flow Catted DP and full cat back system. Also i live in CT so theres a few good choices for Subaru tuning shops like, EFI logics, ECS, and TheshopCT Link to comment Share on other sites More sharing options...
kongzilla Posted February 23, 2015 Share Posted February 23, 2015 this is all you need to know about a reliable vehicle. this is scooby2.5 build thread. http://legacygt.com/forums/showthread.php/2005-stage-3-outback-xt-sti-seats-150039.html?t=150039 Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 Yes i absolutely love that build, thats inspiration for sure for my build, even though mi y build will not be as amazing as his Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 23, 2015 Share Posted February 23, 2015 Looking forward to seeing where this goes. I have eventual plans for my wagon but I have to graduate school first before I start dumping that much money into it too much. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Rhitter Posted February 23, 2015 Share Posted February 23, 2015 Yes i absolutely love that build, thats inspiration for sure for my build, even though mi y build will not be as amazing as his 350 wheel horsepower is a lot. Just be ready to spend. I suggest you define how much you are willing to spend and start your build from there. The other question is - do you know what 350 wheel HP feels like, why did you pick that number, etc, etc. My OBXT build Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 23, 2015 Author Share Posted February 23, 2015 Im looking at around 5k towards this build in the first place, which i know isnt a whole lot towards a build with this amount of HP, want to go second hand on some parts to save some money. And i also have a 67 GTO numbers matching with 360hp stock so id like to make my daily a bit more fun and have a sleeper wagon. Also need to pick up another truck so ill be using that as a DD possibly. My father also has a Germany import Brabus 500sel benz and a done up 240z hes building. I like the platform of these subarus and im far from rich but my car is my pride and joy, so why not make it my own. And the thought of having a great sleeper wagon and keeping my insurance rates down (minus more speeding tickets) i am fond of. Link to comment Share on other sites More sharing options...
05legacygtr Posted February 24, 2015 Share Posted February 24, 2015 I thought I remembered reading somewhere on these forums that if u want anymore than 350 at the wheels; even an aftermarket tmic will be your limiting factor. If it were me and that was my specific goal I'd probably grab a fmic for a little breathing room. Good luck with your parts list, I just had to do the same thing. (Burnt valve, bad ring land) Mr. Tris and Max Capacity's build threads were a lot of help. Just FYI Link to comment Share on other sites More sharing options...
Benjamin M Posted February 24, 2015 Share Posted February 24, 2015 My build on my 05 OBXT 100mm Weisco Pistons ACL Race Bearings New STi Crank Kelford r-199 b camshafts Supertech valves/springs/retainers Mild head porting Arp head bolts Kstech 73mm cai (for fitting fmic) SAMCO 2.4 turbo inlet Dom 1.5xt-r turbo Racer x fmic Turbosmart kompact bpv Grimmspeed 8mm spacers Grimmspeed ebcs Tgv deletes ID 1000cc topfeed injectors ID topfeed conversion rails Agency power parallel fuel line kit Aeromotive fpr Dw 65c fp Dw hardwire fp kit STi fpcm w/ upgraded wiring Killer B holy headers/up pipe Invidia carted dp Nameless performance catback w/ 5in mufflers CM FX350 clutch w/ 08 Wrx SMFW and TOB kit On a conservative tune (my stock 5mt in mind) made 317/317 on awdTuning's mustang dyno. Other misc. to control the above mentioned chaos: Killer b pickup/baffle/pan SAMCO hose suites Group n engine/trans/pitch stop Whiteline bushings everything available plus bump steer kit and rear control arms Whiteline swaybars and endlinks Dba slotted rotors Legacy gt calipers Hawk hps pads Ss brake lines All new gaskets and fluids. Off the top of my head, just to give you an idea. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted February 24, 2015 Share Posted February 24, 2015 I thought I remembered reading somewhere on these forums that if u want anymore than 350 at the wheels; even an aftermarket tmic will be your limiting factor. If it were me and that was my specific goal I'd probably grab a fmic for a little breathing room. Good luck with your parts list, I just had to do the same thing. (Burnt valve, bad ring land) Mr. Tris and Max Capacity's build threads were a lot of help. Just FYI Grimmspeed / Process West TMIC should be able to handle it. Would be a easier with a FMIC though. @ benjamin - I had no idea your car was so built. That must be a blast to drive. My OBXT build Link to comment Share on other sites More sharing options...
700watts Posted February 24, 2015 Share Posted February 24, 2015 Im actually not looking to run E85... probably just because of lack of knowledge of it (really need to educate myself more on E85) but yeah i also have to decide on an intake, any ideas? but im probably going to be running a High flow Catted DP and full cat back system. Also i live in CT so theres a few good choices for Subaru tuning shops like, EFI logics, ECS, and TheshopCT Not sure where I got e85 from, must have corn of the brain. I can tell you from experience, if you want a TRUE sleeper....you don't need cat back. Headers, up/down pipes and possible a little custom work depending on down pipe and high flow cat. Don't get me wrong, you're leaving some power on the table. You should be able to obtain your goals following that and it'll be quiet as stock. I'm running K&N typhoon, it does the job. Oh ya, while your building you'll do your self a BiG favor with TGV deletes at a minimum take out the flaps. Link to comment Share on other sites More sharing options...
Benjamin M Posted February 24, 2015 Share Posted February 24, 2015 Grimmspeed / Process West TMIC should be able to handle it. Would be a easier with a FMIC though. @ benjamin - I had no idea your car was so built. That must be a blast to drive. While I enjoy it, passengers aren't quite as keen to it. It is a loud, vibrating, rattling, highway droning machine. This is my first "built" car so I'm living out my lust for loud and crass. The nameless catback certainly negates most of the sleeper aspect. http://tapatalk.imageshack.com/v2/15/02/24/69a840085de41a42fa6c6cf5da1991b1.jpg http://tapatalk.imageshack.com/v2/15/02/24/802218e194698d63ba4a962d8da7fffe.jpg Sorry to thread jack and a dirty car. More go, less show. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted February 24, 2015 Share Posted February 24, 2015 While I enjoy it, passengers aren't quite as keen to it. It is a loud, vibrating, rattling, highway droning machine. This is my first "built" car so I'm living out my lust for loud and crass. The nameless catback certainly negates most of the sleeper aspect. Sorry to thread jack and a dirty car. More go, less show. Sent from my iPhone using Tapatalk Any dyno graphs with of your set-up? My OBXT build Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 24, 2015 Author Share Posted February 24, 2015 Benjamin M i really admire that build on your XT, i like how clean it is and i really like the stance too. And ive actually got another set of TGV's sitting around so ill probably do the TGV delete on them, im curious to if someone took out the flaps, and the divider, and then still ran the rod, and maybe shaved it down a bit, i wonder if you can still see the power but not have to worry about that CEL you'll typically see, i however also wonder if leaving the rod will effect the air flow much. What are other options to get rid of the CEL? i know a tune can take care of it, just curious if theres other options. Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 24, 2015 Author Share Posted February 24, 2015 And as far as exhaust, i do want some sound... which im not really set on what to run, i do alot of highway driving and want something that wont be TOO loud at a lower rpm like on the highway, but still would like good flow. Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 24, 2015 Share Posted February 24, 2015 And as far as exhaust, i do want some sound... which im not really set on what to run, i do alot of highway driving and want something that wont be TOO loud at a lower rpm like on the highway, but still would like good flow. I've got the Borla resonated catback on my wagon and have driven 2x 13 hour trips and I didn't notice a drone at all. I haven't extended the tips either yet. The one thing you would need though with the outback is to either change the tips to turndowns or acquire the JDM outback rear bumper with cutouts for exhaust or do the cutouts yourself. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
