Bpalumbo159 Posted May 4, 2012 Share Posted May 4, 2012 What is the lowest you can drop your legacy before the tires will rub when you turn, lookin into getting a set of springs and want to go as low as possible! Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 4, 2012 Share Posted May 4, 2012 If you want low, just remove the springs all together. It's been done! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Leke Posted May 5, 2012 Share Posted May 5, 2012 It depends on your wheel and tire combo. Link to comment Share on other sites More sharing options...
katalyst Posted May 5, 2012 Share Posted May 5, 2012 i guess Tein S-techs in that case but the ride quality will be absolutely atrocious on stock struts.....so...not sure why you would want to do it. coilovers would be a better option, then you can just adjust as much as you need before rubbing Link to comment Share on other sites More sharing options...
Bpalumbo159 Posted May 6, 2012 Author Share Posted May 6, 2012 I was lookin into getting know struts, will the ride still be horrible with aftermarket struts? Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 6, 2012 Share Posted May 6, 2012 install spec b struts and you might as well be riding on the back of pegasus himself. Link to comment Share on other sites More sharing options...
katalyst Posted May 6, 2012 Share Posted May 6, 2012 I was lookin into getting know struts, will the ride still be horrible with aftermarket struts? pretty much....cause if you're looking for max drop, the strut will have no room to travel and you'll pretty much just be riding on the bumpstops the entire time. Link to comment Share on other sites More sharing options...
TcDavis Posted May 6, 2012 Share Posted May 6, 2012 My factory struts have Tein springs and I didn't have any problems. Just wasn't low enough so I got Megan coilovers. Link to comment Share on other sites More sharing options...
Vinny78 Posted May 8, 2012 Share Posted May 8, 2012 Go with coils then you can adjust them pretty much to any ride height, BCS all the way FTW Link to comment Share on other sites More sharing options...
CEVENN Posted May 22, 2012 Share Posted May 22, 2012 Tein H-Tech and SpecB Bilstein, with 225/40/18, stil some place, not so uncomfortable on rough french roads! Link to comment Share on other sites More sharing options...
CEVENN Posted June 23, 2012 Share Posted June 23, 2012 With stock size tires (215/45/18): Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 26, 2012 Share Posted June 26, 2012 With stock size tires (215/45/18): God i love 3.0R wheels I would go stock struts and Tein S-Techs springs for a low look IF you dont want to spend $$$ for coils. Link to comment Share on other sites More sharing options...
valadares Posted June 26, 2012 Share Posted June 26, 2012 With stock size tires (215/45/18): :wub:So beautiful Special Leggy Link to comment Share on other sites More sharing options...
