lulzcow Posted August 24, 2011 Share Posted August 24, 2011 I'm not proud of this, although it seems like a really cool and potentially engine saving feature on my car. Whenever the engine gets to its redline, the transmission kicks itself out of gear. Is this normal for our cars? I have never had this happen in any other car I have owned, although the only 5 speed was a 90's Civic hatch. PS I don't redline intentionally, when I first got the car it redlined at 4500rpm, and until I get the ecu sorted out it redlines right at the beginning of the redline area on the tach. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 24, 2011 Share Posted August 24, 2011 hmm.. its possible the red line does shake the engine pretty good. along with tranny. to pop it out. i have never had this happen in my car. haha BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 24, 2011 I Donated Share Posted August 24, 2011 Your transmission isn't suppose to "kick out of gear" at redline. Your transmission is on its way out. Thats damaged syncros my friend. So yeah, its not a "cool feature" -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 24, 2011 Share Posted August 24, 2011 that sucks.. glad im auto BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 24, 2011 I Donated Share Posted August 24, 2011 that sucks.. glad im auto The 4EAT has more problems then the 5MT! What are you talking about!!!??!!! lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 24, 2011 Share Posted August 24, 2011 not if you treat them well. atf changes and filters. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 24, 2011 I Donated Share Posted August 24, 2011 Two words.... torque bind -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 24, 2011 Share Posted August 24, 2011 no problem BNR18g on 93oct Link to comment Share on other sites More sharing options...
Baddog Posted August 25, 2011 Share Posted August 25, 2011 Torque bind is usually easy to fix. Mine and Erins car got new ATF and Lubeguard ATF additive. All gone! Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 25, 2011 Share Posted August 25, 2011 Your transmission isn't suppose to "kick out of gear" at redline. Your transmission is on its way out. Thats damaged syncros my friend. So yeah, its not a "cool feature" Probably not a damaged synchro. The older boxes had an issue with the rear-most nut on the mainshaft coming loose and letting everything slide backwards. Tighten that nut to the 180ft-lbs, or whatever that torque value is, and everything should go back to normal. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
lulzcow Posted August 25, 2011 Author Share Posted August 25, 2011 Cool thanks guys! Link to comment Share on other sites More sharing options...
vr4babe13 Posted August 25, 2011 Share Posted August 25, 2011 Probably not a damaged synchro. The older boxes had an issue with the rear-most nut on the mainshaft coming loose and letting everything slide backwards. Tighten that nut to the 180ft-lbs, or whatever that torque value is, and everything should go back to normal. If its not what he said it sounds like a worn blocker ring. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 26, 2011 Share Posted August 26, 2011 Probably not a damaged synchro. The older boxes had an issue with the rear-most nut on the mainshaft coming loose and letting everything slide backwards. Tighten that nut to the 180ft-lbs, or whatever that torque value is, and everything should go back to normal. what is the rear most nut? pictures? BNR18g on 93oct Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 26, 2011 Share Posted August 26, 2011 The nut on the back of the main shaft inside the case. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
xXChaosXx Posted August 29, 2011 Share Posted August 29, 2011 blocker ring or snap ring, try tapping the shifter harder into the gear right before you redline, stupid idea, i know but try it Link to comment Share on other sites More sharing options...
