kensukikatayo Posted August 2, 2008 Share Posted August 2, 2008 I need to put on a 5mm spacer with longer bolts. Does anyone know roughly how much pressing on longer bolts will be and potential problems to look out for? Thanks. 2007 OBP Legacy 2.5GT 5MT - vBGarage 2001 SSM 3.2CL Type-S Link to comment Share on other sites More sharing options...
fweasel Posted August 2, 2008 Share Posted August 2, 2008 use hubcentric spacers or go home. Eibach makes a quality spacer. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2008 Share Posted August 3, 2008 Hubcentric or DIAF. H&R are good too use a piece of steel pipe and some washers and an impact driver to press the new studs in. it's not fun My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
kensukikatayo Posted August 3, 2008 Author Share Posted August 3, 2008 I'm looking at the H&R's now if anything, unless someone can vouch for the Ichiba ones. Would it be possible to use open-ended lug nuts instead of pressing on the extended lug nuts since it is only 5mm or is that unsafe? It's just difficult to justify the cost of pressing on the extended lug bolts for such a small difference. 2007 OBP Legacy 2.5GT 5MT - vBGarage 2001 SSM 3.2CL Type-S Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2008 Share Posted August 3, 2008 open-ended nuts won't be any different than regular ones in this scenario.... unless you press in larger studs then run without the spacers My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
kensukikatayo Posted August 3, 2008 Author Share Posted August 3, 2008 It seems as if I have to press in the lug bolts no matter what? What would be the typical price for something like this? I got quoted $180 to press in lug bolts for all 4 corners and for the install of the wheel spacers (which is obviously easy except for the pressing). Thanks for the help Mike. 2007 OBP Legacy 2.5GT 5MT - vBGarage 2001 SSM 3.2CL Type-S Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2008 Share Posted August 3, 2008 sounds like a good price. if you do it yourself you'll spend alot more time My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Paisan Posted August 3, 2008 Share Posted August 3, 2008 Spacers are never a good option IMO. You are better off finding rims with the offset that clears whatever you are trying to clear. -mike Link to comment Share on other sites More sharing options...
FX35B4 Posted August 3, 2008 Share Posted August 3, 2008 This is how they look with 20mm longer hub bolts. http://i261.photobucket.com/albums/ii56/fx35bl5/SANY0033-1.jpg Bought 10,8,5,3mm spacers and hub center rings.Right now,I'm using 5mm http://i261.photobucket.com/albums/ii56/fx35bl5/SANY0034-1.jpg This is how they look with open-ended lug nuts. http://i261.photobucket.com/albums/ii56/fx35bl5/SANY0049-1.jpg If you only use 5mm spacers, go for 10mm longer stud bolts. If you use thicker than 10mm spacers, go for 20mm longer one. Hope this will help you. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 4, 2008 Share Posted August 4, 2008 Spacers are never a good option IMO. You are better off finding rims with the offset that clears whatever you are trying to clear. -mike +1 FX35B4 --- Those are not Hubcentric spacers. You're looking for trouble down the line. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
kensukikatayo Posted August 4, 2008 Author Share Posted August 4, 2008 The more I look into this the less I want to do this.. I guess a set of Brembo fronts are going to be up for sale.. 2007 OBP Legacy 2.5GT 5MT - vBGarage 2001 SSM 3.2CL Type-S Link to comment Share on other sites More sharing options...
axis008 Posted August 4, 2008 Share Posted August 4, 2008 Get new wheels man! -ben Link to comment Share on other sites More sharing options...
kensukikatayo Posted August 4, 2008 Author Share Posted August 4, 2008 Mucho money Ben, which ones would you recommend? 2007 OBP Legacy 2.5GT 5MT - vBGarage 2001 SSM 3.2CL Type-S Link to comment Share on other sites More sharing options...
axis008 Posted August 4, 2008 Share Posted August 4, 2008 Not a fan of Rotas.... So some good semi-low cost wheels I'd recommend are Work Wheels (XD9, XT7). There are always deals on NASIOC. Plus if you have 18s now, you could use the same tires. -ben Link to comment Share on other sites More sharing options...
mwiener2 Posted August 4, 2008 Share Posted August 4, 2008 you can get wheels that fit over the brembos for about $100 a wheel My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
