eljefe1981 Posted January 17, 2013 Share Posted January 17, 2013 At times while I'm driving the sport light on my 05 GT limited just starts flashing for no reason that I can think of. The car has 140k and it seems to be running fine except for the light flashing. Any help on the flashing light is appreciated. Link to comment Share on other sites More sharing options...
-Samurai- Posted January 19, 2013 Share Posted January 19, 2013 If you actually switch into sport mode does the Sport light stay on, or does it still flash? Link to comment Share on other sites More sharing options...
eljefe1981 Posted January 19, 2013 Author Share Posted January 19, 2013 The lights continue flashing no matter what I do. The only way it goes out is if I shut the car off Link to comment Share on other sites More sharing options...
-Samurai- Posted January 19, 2013 Share Posted January 19, 2013 That is odd, dont think I have ever heard of this happening before. Wonder if it has to do with the ECU needing reflashed or something like that. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted January 19, 2013 Share Posted January 19, 2013 Do your check engine & cruise lights work? Are they doing anything? Tits mcgee Link to comment Share on other sites More sharing options...
eljefe1981 Posted January 20, 2013 Author Share Posted January 20, 2013 I can ser the car in cruise control no problem. Also, I do not have the check engine light on. Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 20, 2013 Share Posted January 20, 2013 FSM mentions this. 5-AT Diag -2. Basically says to hook up to computer to read diag code. My guess is this is a manufacturer-specific code so you'll probably need the dealer. Could be as simple as a loose connector. It just a matter of deciding whether to troubleshoot on your own or pay up the diagnostic fee and (maybe) know for sure... Link to comment Share on other sites More sharing options...
frank_ster Posted January 20, 2013 Share Posted January 20, 2013 sport mode flashing is like check engine for the tranny. that being said you can pull the codes by the onboard diagnostic system ( connect green terminals inside fuse box push the trip meter with in 5 seconds of turning on the key and voila you have your error code search for more information all 05 legacys have this ability)  a common thing with 05's i can make any 05 auto sport light flash by either driving the car put in N and shut of engine and then turn the key back on while the car is still moving. of by turning the key on and putting the car into N and rolling down a hill. i think that code is like 730 or 728 something about can comunication error. basically the tranny is turning but the engine is not and the tcu freaks out about that. my bosses 07 doesnt do that so i guess they fixed that programming. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
rob-2 Posted January 22, 2013 Share Posted January 22, 2013 Could it be the switch in the shifter is on the way out? Link to comment Share on other sites More sharing options...
frank_ster Posted January 22, 2013 Share Posted January 22, 2013 doubt it .. its probably a sensor .. my front speed sensor broke when my center diff blew up back in 2008 Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
eljefe1981 Posted January 24, 2013 Author Share Posted January 24, 2013 Did the light flash after the speed sensor broke? Link to comment Share on other sites More sharing options...
frank_ster Posted January 24, 2013 Share Posted January 24, 2013 ^ yes any trans malfunction will cause the sport light to flash. most of them will cause the cel and cruse to flash also. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
