FJ60 Posted December 9, 2012 Share Posted December 9, 2012 Two alignment and brake shops couldn't properly align my front. Both said I need an upper strut tower cam caster kit which they can find online for most makes except Subaru. Anyone heard of such a kit, and if so, know where I can purchase one for a Subie? BTW, I'm running pinks/Bilstein HDs. Thank you in advance! [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 9, 2012 Share Posted December 9, 2012 If they can't align it, something is wrong. Either something is broken, or they don't know what they are talking about. Find out where local auto-crossers go for alignments, and ask them. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
FJ60 Posted December 9, 2012 Author Share Posted December 9, 2012 I'll ask around. In the meantime, have you ever heard of an "upper strut tower cam caster kit"? Is it the same thing as an adjustable camber/caster plate? [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 9, 2012 Share Posted December 9, 2012 Probably means camber plates. You shouldn't need them. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jamal Posted December 10, 2012 Share Posted December 10, 2012 Do you have a printout or know the current alignment and what specifically they can't get into spec? Link to comment Share on other sites More sharing options...
Dov Posted December 10, 2012 Share Posted December 10, 2012 Our stock caster is too shallow for a caster plate, which is why we only have camber plates available. The closest you'll get is a lca bushing that adds caster. But that shouldn't be nessecary for the setup you have. Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 10, 2012 Share Posted December 10, 2012 Our stock caster is too shallow for a caster plate, which is why we only have camber plates available. The closest you'll get is a lca bushing that adds caster. But that shouldn't be nessecary for the setup you have. Swap camber plates from side to side, and they turn into camber/caster plates. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
FJ60 Posted December 10, 2012 Author Share Posted December 10, 2012 Do you have a printout or know the current alignment and what specifically they can't get into spec? Here's what the first shop gave me. The circled numbers are red.FJ60 alignment printout DOC.PDF [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
jamal Posted December 10, 2012 Share Posted December 10, 2012 Looks like your alignment guy just doesn't know what he's doing. The upper bolt where the strut attaches to the upright is cammed for camber adjustment. They made no adjustments to the camber at all and don't seem to have touched the rear either (where only the toe is adjustable, but it should be zeroed). Also, having -1 degree in the front is a good thing, so when you go back make sure they adjust the side with 0 to have more and not the side with -1 down to zero. Link to comment Share on other sites More sharing options...
FJ60 Posted December 11, 2012 Author Share Posted December 11, 2012 Looks like your alignment guy just doesn't know what he's doing. The upper bolt where the strut attaches to the upright is cammed for camber adjustment. They made no adjustments to the camber at all and don't seem to have touched the rear either (where only the toe is adjustable, but it should be zeroed). Also, having -1 degree in the front is a good thing, so when you go back make sure they adjust the side with 0 to have more and not the side with -1 down to zero. Going to a third shop today. Wish me luck! [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
FJ60 Posted December 15, 2012 Author Share Posted December 15, 2012 You guys were right! The 2 alignment places I visited did not know what they were doing. The 3rd shop determined that the lca bushings were shot and the reason behind my alignment problem in less than 5 minutes. Makes me wonder whether the first 2 techs were lazy or inept. [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
AZP Installs Posted December 15, 2012 Share Posted December 15, 2012 You guys were right! The 2 alignment places I visited did not know what they were doing. The 3rd shop determined that the lca bushings were shot and the reason behind my alignment problem in less than 5 minutes. Makes me wonder whether the first 2 techs were lazy or inept. Did they replace the LCA Bushings? If not we can offer the Whiteline Upgraded LCA Bushings (they allow for greater adjustment of the caster) and are stiffer and more durable than stock replacement ones. Glad to hear that you found a competent place to work on your car. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
FJ60 Posted December 16, 2012 Author Share Posted December 16, 2012 Did they replace the LCA Bushings? If not we can offer the Whiteline Upgraded LCA Bushings (they allow for greater adjustment of the caster) and are stiffer and more durable than stock replacement ones. Glad to hear that you found a competent place to work on your car. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" sti bushings are going in this week [FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT] Link to comment Share on other sites More sharing options...
