ckinyon Posted August 11, 2014 Share Posted August 11, 2014 I'm putting an 05 lgt back together and twords the end can't figure out where these two wires go. They are on the drivers side and they look like ground wires. But I'm not sure. I think I found the spot but I don't want to be wrong. The spot is just a post coming off the block with two threaded holes. Could this be? .... Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2014 Share Posted August 11, 2014 Most likely, but I can't see the picture. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted August 11, 2014 Share Posted August 11, 2014 FWIW, http://legacygt.com/forums/showthread.php/engine-grounds-locatedi-228980.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
