Suby Forever Posted August 22, 2010 Share Posted August 22, 2010 Help! We have 3 Legacys, an 02 Legacy GT Ltd sedan and 2 05 Legacy GT Ltd turbo wagons. Have owned Forester and Impreza also. Obviously love them. Have even swapped motors on two of them. No problems but something simple like ps pump replacement is kicking my a..! I read the advice posts to lift front end and turn lock to lock. Have done that with car off then on. Did that all evening yesterday. When it foamed I quit and gave it time to settle down. Got in to try it this morn and steering totally tight like i hadnt bled it. Jacked it back up today and lock to lock again. When car is off it will release a little bubble but it also drains and refills reservoir as u turn wheel back and forth. Then if I start car it belches fluid out the top again. When does it stop!? Any advice? Link to comment Share on other sites More sharing options...
Osei Posted August 22, 2010 Share Posted August 22, 2010 can only suggest what Chiltons says. It does say to NOT turn wheel lock to lock. just continually side to side. Letting it settle and again until no more air bubbles or foam occur. O. Link to comment Share on other sites More sharing options...
Suby Forever Posted August 22, 2010 Author Share Posted August 22, 2010 Tthanks. I thought other advice i had read was L to L. But I will try just doing partial turn. I read that the system is designed to bleed off air by itself. Im assuming that just means little residual amts. Not all the air. Got to get it fixed. Daughter needs to go back to work tomorrow. Link to comment Share on other sites More sharing options...
Tracer-X Posted August 22, 2010 Share Posted August 22, 2010 I have swapped power steering racks and when I bled it I did the lock to lock technique and it worked for me. I wish I had some better advice for you. Jump on it, Let's do it, Ride it, My Pony... EL4NFZT7 Link to comment Share on other sites More sharing options...
tbssubaru Posted April 4, 2012 Share Posted April 4, 2012 i'm having a similar problem with foamy and overflowing ps fluid from the resevoir, steering is near impossible to turn, what did you fix end up being ? Link to comment Share on other sites More sharing options...
amp0412 Posted April 4, 2012 Share Posted April 4, 2012 After I changed my ps rack I know not the pump but same idea. I had to turn it back and forth for a while and then had to drive it and check the fluid for about a day until it felt perfectly normal. Link to comment Share on other sites More sharing options...
