erickrocks1126 Posted July 21, 2016 Share Posted July 21, 2016 Hey all; so on Wednesday I pulled into my driveway after work and noticed the check engine light was on. Came back to it later, still on. Plugged in my bluetooth OBDII reader and checked for codes using both Torque and Carista; neither found any fault codes. So, I cleared the code. It hasn't come back since, so far. Has anyone had a CEL come on and when you plug in an OBDII reader it shows no codes are active? Link to comment Share on other sites More sharing options...
Brighton96 Posted July 21, 2016 Share Posted July 21, 2016 Was it flashing or just on? Sometimes you can get a CEL without a code if it something like a brief short caused by water somewhere it shouldn't be Link to comment Share on other sites More sharing options...
erickrocks1126 Posted July 21, 2016 Author Share Posted July 21, 2016 Was it flashing or just on? Sometimes you can get a CEL without a code if it something like a brief short caused by water somewhere it shouldn't be It was on without flashing. Link to comment Share on other sites More sharing options...
Brighton96 Posted July 21, 2016 Share Posted July 21, 2016 Was the car acting weird when the light was on? Link to comment Share on other sites More sharing options...
erickrocks1126 Posted July 23, 2016 Author Share Posted July 23, 2016 Was the car acting weird when the light was on? Nope. Was driving home from work and as I was pulling into my driveway I saw it was on (it wasn't when I left work 15 minutes prior). Otherwise, there was nothing weird about the car that I noticed. New development: CEL on steady is back on again, same circumstance; left work last night it wasn't on, pulled into driveway it was. I haven't had a chance yet to see if there are codes with this one. But thinking of it, on both occasions it's been very hot out (100 degrees F) and I drove home with the AC on at nearly full blast the whole way home. That may be coincidental, but the days in-between I didn't have the A/C on, or if I did, I only had the fan speed up to 2 (out of 4). Link to comment Share on other sites More sharing options...
twisty Posted July 25, 2016 Share Posted July 25, 2016 Has anyone had a CEL come on and when you plug in an OBDII reader it shows no codes are active? ive had to run my code checker a couple times in a row before to get codes to show up. i figured it was the elm327 bluetooth thing failing tho, not the car Link to comment Share on other sites More sharing options...
Setnev Posted July 27, 2016 Share Posted July 27, 2016 It's dependent on your scanner, not the program you use. Some scanners are unable to detect the proper protocol the OBDII system uses and if it can't autodetect it, it will use the default for the scanner. I have an OBDLink LX bluetooth scanner that works pretty awesome. I've used it on just about every car I've come across and the app is top notch for showing statistics on the engine sensors. Link to comment Share on other sites More sharing options...
Thor294 Posted July 28, 2016 Share Posted July 28, 2016 If the light is on while running, there is a code. Could be your scanner not reading it Link to comment Share on other sites More sharing options...
erickrocks1126 Posted July 29, 2016 Author Share Posted July 29, 2016 So I rescanned the car again (I have a BAFX bluetooth OBDII dongle) and got a p0325 code. Looked it up and that's apparently the knock sensor circuit malfunction code. So I ordered a new one, but go figure, the light goes off and has been off now for the last 2 days. Link to comment Share on other sites More sharing options...
Thor294 Posted July 29, 2016 Share Posted July 29, 2016 Knock sensor light does that. Did it to me Link to comment Share on other sites More sharing options...
twisty Posted August 2, 2016 Share Posted August 2, 2016 ya, mine does that too. annoying. Link to comment Share on other sites More sharing options...
erickrocks1126 Posted August 4, 2016 Author Share Posted August 4, 2016 Light came back on again for a day. Now it's back off. Got the new knock sensor in so I'll try to install this weekend if I get around to it. Car drives fine otherwise. Link to comment Share on other sites More sharing options...
RustyRuu Posted August 4, 2016 Share Posted August 4, 2016 make sure you put the knock sensor in at the proper position, wire at the 1:00 oclock/ 1:30 position if you are standing looking at the car, as you would be servicing it, but you probably got that Link to comment Share on other sites More sharing options...
erickrocks1126 Posted August 5, 2016 Author Share Posted August 5, 2016 make sure you put the knock sensor in at the proper position, wire at the 1:00 oclock/ 1:30 position Will do, thanks! Link to comment Share on other sites More sharing options...
erickrocks1126 Posted August 14, 2016 Author Share Posted August 14, 2016 Finally changed out the sensor. Cleared the code after and drove for a bit. So far so good. Link to comment Share on other sites More sharing options...
