Baguila2 Posted February 8, 2015 Share Posted February 8, 2015 Good Morning all! Went to autozone this morning to pick up an oil filter for my oil change this afternoon. Got the car up on ramps when I got home. Crawled underneath to get started and noticed something ugly. Found some gray/dark green fluid on my uppipe...I thought it was oil, but I can't really tell. Any help on this and where it might be coming from? This is all on my up pipe, it's splattered, and looks like it's from this morning to be honest. Link to comment Share on other sites More sharing options...
V8lolsubie Posted February 8, 2015 Share Posted February 8, 2015 The answer is in this picture. Inner CV axle boot either has a hole in it or is ripped. Inspect it for tears. Link to comment Share on other sites More sharing options...
Baguila2 Posted February 8, 2015 Author Share Posted February 8, 2015 That's what I was thinking as well once I got back under there. I haven't found a rip yet, but it looks like some of the grease is definitely covering that as well Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 8, 2015 I Donated Too Share Posted February 8, 2015 Yep that's CV grease. You can get a repair kit for that OEM axle or you can replace the whole thing. I got the boot repair kit from Subaru and it worked out very well but you need to be sure you don't have any damage from dirt getting in but it looks to me like yours hasn't been broken open too long. Link to comment Share on other sites More sharing options...
Baguila2 Posted February 9, 2015 Author Share Posted February 9, 2015 Thanks for all the help. I'm an idiot and just got scared too fast. But yes, went and picked up a new CV axle after seeing the posts about nightmare rebuilds. I guess I'll be putting it in this weekend! Thanks again Link to comment Share on other sites More sharing options...
JayInVA Posted February 9, 2015 Share Posted February 9, 2015 Thanks for all the help. I'm an idiot and just got scared too fast. But yes, went and picked up a new CV axle after seeing the posts about nightmare rebuilds. I guess I'll be putting it in this weekend! Thanks again Where did you buy your axle and did you get brand new or remanufactured? Link to comment Share on other sites More sharing options...
theflystyle Posted February 9, 2015 Share Posted February 9, 2015 Im surprised you didnt smell something burning with the amount of grease on there. Link to comment Share on other sites More sharing options...
alaskajoel Posted February 9, 2015 Share Posted February 9, 2015 Im surprised you didnt smell something burning with the amount of grease on there. This--That shiz is usually super stinky. Link to comment Share on other sites More sharing options...
Baguila2 Posted February 10, 2015 Author Share Posted February 10, 2015 Well I think the boot had literally split that morning. The grease was really fresh and not all that dirty yet. Probably why I didn't have any smell. I got a brand new one instead of a re-manufactured. I got a new one from Autozone since I wanted to do it that morning. I was doing some research on here and it sounds like these things are basically all the same quality regardless of brand and whatnot. Pretty much every brand I found had at least one or two bad reviews....All around the same price too. Threw it on and it's been quiet and working well. I suppose I'll update if something goes wrong! Link to comment Share on other sites More sharing options...
Baguila2 Posted February 20, 2015 Author Share Posted February 20, 2015 UPDATE: I'm stuck....Got the entire assembly out fairly easily after following the instructions on this website...Didn't think it would b a problem as I've done several on my roomate's Honda. Anyways, we went to re-install the new assembly, and I can't do it. I get it all the way into the vehicle. It seems to get "stuck" about 2/3's of the way in. I've watched several videos and re read the write up, but no one seems to have any issues re-inserting these. Any ideas? Link to comment Share on other sites More sharing options...
shortfusemonkey Posted February 20, 2015 Share Posted February 20, 2015 just got to ask, are you sure it is the correct one? I had that issue on my Nissan before, come to find out, it was not the correct one. Link to comment Share on other sites More sharing options...
JayInVA Posted February 20, 2015 Share Posted February 20, 2015 UPDATE: I'm stuck....Got the entire assembly out fairly easily after following the instructions on this website...Didn't think it would b a problem as I've done several on my roomate's Honda. Anyways, we went to re-install the new assembly, and I can't do it. I get it all the way into the vehicle. It seems to get "stuck" about 2/3's of the way in. I've watched several videos and re read the write up, but no one seems to have any issues re-inserting these. Any ideas? What's the part # on the box from Autozone? Is it the Duralast brand? If so, those are made by A1 Cardone. Just wanted the part # to make sure it's the correct piece (not sure why it would't be). Also, you have to push it fairly hard to get seated. I pressed it in gingerly trying not to do any damage but eventually I just had to put some grunt into it (one good shove) and it popped right into place. Link to comment Share on other sites More sharing options...
Sk8erOrd Posted February 20, 2015 Share Posted February 20, 2015 How hard is this swap? I need to do mine, and am debating between paying someone (~$200/side parts & labor) or just doing them myself... Are the Autozone ones ok? Should I buy it somewhere else? Reman vs. new? 2015 Mustang Ecoboost Premium w/ PP (6MT) 2006 LGT Ltd 5MT OBP Cobb Short Throw Shifter | GS Catless Up Pipe Gone Link to comment Share on other sites More sharing options...
alaskajoel Posted February 20, 2015 Share Posted February 20, 2015 I've done both, and while I didn't have a problem with the rear at all, I blew out a transmission axle seal doing the front somehow. Not sure if I filled the fluid up too much, or what. Link to comment Share on other sites More sharing options...
Baguila2 Posted February 20, 2015 Author Share Posted February 20, 2015 I'm not sure on anything at this point....The part number on the autozone part was 7336N if that helps :/ Link to comment Share on other sites More sharing options...
Baguila2 Posted February 20, 2015 Author Share Posted February 20, 2015 We can't get it out no matter what we try now, and we don't want to push it any further in in case we damage that seal or whatever. I might be in over my head here now, but I'm not sure. The parts lined up almost identically. Now the axle is "stuck" like i mentioned. Can't pull it out anymore, and I'm afraid to push it further in now in case its the wrong part or something Link to comment Share on other sites More sharing options...
Baguila2 Posted February 20, 2015 Author Share Posted February 20, 2015 The removal the first time was actually fairly easy. We did everything according to the guide I found on this site actually where a guy was fixing a boot. (sorry don't have time to find the link again) anyways, the only snag happened once we were putting the new assembly back in. We lined everything up and tried to put it in as level and straight as possible (also suggested in that thread) and we got it about 2/3 of the way in and now it wont go in or out. Maybe I need to muscle up and try to seed it in all the way? Thought I was already pushing pretty hard :/ Link to comment Share on other sites More sharing options...
apexi Posted February 20, 2015 Share Posted February 20, 2015 I replaced both of my front axles for the first time around 4 months ago, and I was surprised by how hard I had to push to get them in all the way. They eventually "popped" into place with a little extra muscle. I used regular 7336 axles which are the remanufactured axles, vs the 7336N which is new. I think what worked best for me was "pumping" the axle into the transmission. I think I ended up holding the shaft in the middle, and sort of pumping it in like a toilet plunger. I had never replaced an axle before, so I don't know how hard this job compared to replacing axles on another car. Link to comment Share on other sites More sharing options...
MAP Posted February 20, 2015 Share Posted February 20, 2015 I would get that new one off and inspect the splines for damage. Something doesn't seem right if it's getting stuck part way in. Link to comment Share on other sites More sharing options...
apexi Posted February 20, 2015 Share Posted February 20, 2015 I wasn't thinking when I made my post earlier. I thought you were just having trouble getting the new axle to go in, I forgot that you mentioned it was stuck, and wouldn't slide in or out. Link to comment Share on other sites More sharing options...
