ndmx52 Posted May 24, 2009 Share Posted May 24, 2009 So I have no idea why my car won't beep when I lock/unlock it. I have used the instructions in the user's manual to activate/deactivate the beeps, but no such luck. I did notice the other day that I had a unplugged harness (female end. yellow/black and black wires) that splits off at the same point as the harnesses for the horn. I couldn't see where it went to and I'm curious if the "beeper" might be located next to the horns. any ideas? Link to comment Share on other sites More sharing options...
blackfang Posted May 25, 2009 Share Posted May 25, 2009 Have you checked to make sure it isn't in valet mode? [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
ndmx52 Posted May 26, 2009 Author Share Posted May 26, 2009 I found this picture while looking around on the forum. Is this white box the buzzer? I assume this is were my plug should be going to. Does anyone have a correct name for this thing or a part number? I'm thinking the previous owner took it out since I can't seem to find it in there. Link to comment Share on other sites More sharing options...
TruAlk Posted June 1, 2009 Share Posted June 1, 2009 If you have a seperate key pad for lock/unlock from the key, read the directions on the back of that. The steps are: 1. press unlock 2. press and hold lock and unlock for 2 seconds. This happened to me one time and I was like WTF until i figured this out. Try that and if it does not work, then maybe you are missing the buzer Link to comment Share on other sites More sharing options...
TruAlk Posted June 1, 2009 Share Posted June 1, 2009 ha, just read that you already tried, this, i guess i should read more carefully, any luck on getting this fixed yet? Link to comment Share on other sites More sharing options...
CasopoliS Posted June 1, 2009 Share Posted June 1, 2009 I found this picture while looking around on the forum. Is this white box the buzzer? I assume this is were my plug should be going to. Does anyone have a correct name for this thing or a part number? I'm thinking the previous owner took it out since I can't seem to find it in there. That white box is the beeper. If its not there, you need it. Link to comment Share on other sites More sharing options...
Woodstock Posted July 25, 2009 Share Posted July 25, 2009 same problem here! It rained hard last night, then today when I tried to unlock the car. I hear no beep, and sometimes just a faint beep. Did it get wet? Link to comment Share on other sites More sharing options...
