Kaptan Posted April 6, 2005 Share Posted April 6, 2005 Does anyone know if there is a setting that can be changed so that the sunroof can be closed with one click instead of two? I know that it's there for safety reasons, but it closes so slow that I don't think that would be an issue:lol: I got used to my previous car's sunroof closing when the ignition was turned off. Link to comment Share on other sites More sharing options...
Xenonk Posted April 6, 2005 Share Posted April 6, 2005 it's for that half-open window. I am sure the dealer can either replace the relay or maybe the ECU parameter that the dealer can change. Keefe Keefe Link to comment Share on other sites More sharing options...
sde Posted April 6, 2005 Share Posted April 6, 2005 you're 'sure they can', ... but the question is 'would they?' .. i would put $100 that my dealer would give me a funny look and say that is just how it is. that would be a modification and therfore void the warranty Link to comment Share on other sites More sharing options...
Deer Killer Posted April 6, 2005 Share Posted April 6, 2005 it's for that half-open window. I am sure the dealer can either replace the relay or maybe the ECU parameter that the dealer can change. Keefe Really? Mine makes a crapload of wind noise like that.. hard to believe.. but maybe mine makes windnoise more than normal... hmmm Link to comment Share on other sites More sharing options...
Kaptan Posted April 6, 2005 Author Share Posted April 6, 2005 ^ Yeah way too much noise at half open. I believe when you open the sunroof, you can manually hold the switch and let go at the desired opening? I'll call my dealer tomorrow to see if this is an ECU parameter that can be changed. Hmmm....maybe COBB can add this to their next AP version Link to comment Share on other sites More sharing options...
dustinw Posted April 6, 2005 Share Posted April 6, 2005 I'd be real surprised if the dealer could change that. If so I'll get in line for it, but I doubt it. Link to comment Share on other sites More sharing options...
sde Posted April 6, 2005 Share Posted April 6, 2005 i like the sound as the sunroof is closing .. sshhhhhhhooooooooooeeeeeeeeeeeiiiiiiiiiiipt Link to comment Share on other sites More sharing options...
Kaptan Posted April 7, 2005 Author Share Posted April 7, 2005 ^Especially when you are moving at about 70mph when closing. Link to comment Share on other sites More sharing options...
eamiller Posted April 7, 2005 Share Posted April 7, 2005 Unfortunately, looking at the service manual, the sunroof control module is integrated into the motor assembly. It does attach to the ABS (or VDC if so equipped) for something.. It's not clear why.. It doesn't seem likely that it's programmable, unless that's a CAN line running to the ABS module. Link to comment Share on other sites More sharing options...
Xenonk Posted April 7, 2005 Share Posted April 7, 2005 safety locking mechanism to keep close or keep the window open if the car is going to roll over?? Keefe Keefe Link to comment Share on other sites More sharing options...
RobE Posted July 9, 2007 Share Posted July 9, 2007 bumpdate? has anybody successfully done this? http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Scooter Posted July 9, 2007 Share Posted July 9, 2007 Yeah, I'd be up for a fix, too - closing the sunroof is the most annoying thing ever! Well, you know, after the seat belt chime and the slow double-tap of the keyfob to open all doors. (Both of which have been successfully resolved.) Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Bdubs Posted July 9, 2007 Share Posted July 9, 2007 I've owned 3 Subarus and every one of them have done that. Its a little annoying, but at least they know offer two clicks instead of having to hold it down until it stops and then hold it down again until it closes into position. Link to comment Share on other sites More sharing options...
Spec B Posted July 10, 2007 Share Posted July 10, 2007 I think the 2 clicks is to protect kids from getting their head or limbs caught in the closing sunroof. I think (to protect Subaru legally) it requires pinch protection in order for the sunroof to close with one touch.. Same concept with the one touch up windows. Definately annoying..especially since my last 2 cars had the one window/sunroof touch feature. Link to comment Share on other sites More sharing options...
RobE Posted July 10, 2007 Share Posted July 10, 2007 Our sunroofs have pinch protection. Try it out. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
SpecBee Posted July 11, 2007 Share Posted July 11, 2007 Has anyone checked for an end switch or midway travel switch? If one did exist it could be easily disabled or wired through. Link to comment Share on other sites More sharing options...
mikeyd Posted April 23, 2012 Share Posted April 23, 2012 Theres a more active thread for this here: http://legacygt.com/forums/showthread.php/sunroof-mod-73568.html Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
mikeyd Posted July 10, 2012 Share Posted July 10, 2012 A solution is in the works: http://legacygt.com/forums/showthread.php?t=73568&goto=newpost Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
mikeyd Posted October 9, 2012 Share Posted October 9, 2012 http://legacygt.com/forums/showthread.php/1-touch-sunroof-close-and-more-193882.html Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
