lightweight14 Posted June 16, 2011 Share Posted June 16, 2011 Mechanic thinks I have rod knock and spun bearing. Need a somewhat cheap long block for a 2005 Legacy GT automatic. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted June 16, 2011 Share Posted June 16, 2011 Long Block or Short Block? You can pick up a short block a lot easier. You can get a short block from http://www.FredBeans.com or probably most other dealers for under $2k. One dealer has a special on ebay for $1800. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280553622985&viewitem=&sspagename=STRK%3AMEWAX%3AIT If there's a problem with the heads, send them out to a machine shop. Other route would be looking for used engines off some place like car-part.com http://www.ImportImageRacing.com also has some nice deals on short blocks. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 16, 2011 Share Posted June 16, 2011 Mechanic thinks I have rod knock and spun bearing. Need a somewhat cheap long block for a 2005 Legacy GT automatic. Cheap and EJ255 don't go together. You can do a web search for "used ej255 long block and see what pop's up. God Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted June 16, 2011 Share Posted June 16, 2011 Cheap and EJ255 don't go together. Amen on that one! Link to comment Share on other sites More sharing options...
Max Capacity Posted June 16, 2011 Share Posted June 16, 2011 A new oem short block is $2000+/- a 100. you'll need to have your heads checked by a machine shop. Any where from I'd guess $500-2000 depending on what's needed. Then labor to rebuild, and install plus removal cost. I have a buddy that owns a auto machine shop, he told me if I'm not looking for high HP just buy a new oem short block and have them redo my heads. He can't do the short block cheaper then the factory. They would give me back a long block. That price was north $3500. Now if you were going to do all the labor...that may be different. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
c-lo Posted June 16, 2011 Share Posted June 16, 2011 nice to know. something like that happens to my car it's bye bye legacy hello TDI or outback! wonder how much one could sell a wagon sans the engine for? hmmm....... not that I need it now. car is running like a top. (knock on wood) 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
