Heat Posted May 4, 2009 Share Posted May 4, 2009 I think the title speaks for itself. I have a completely stock 2009 LGT with 15 k miles on it. Within a month I'm going to be getting an access port and will tell Mike at Tuning Alliance that I'm running an AVO drop in filter. Am I safe to run the AVO filter without tuning? I've heard on here that the car can run a bit lean. Thoughts or suggestions? Thanks in advance. Link to comment Share on other sites More sharing options...
nka Posted May 4, 2009 Share Posted May 4, 2009 I thinks it's lean when you have downpipe + avo filter with no tune, not the filter alone. But well, I wish to have the answer too (but I'm on 05) Link to comment Share on other sites More sharing options...
FireB Posted May 5, 2009 Share Posted May 5, 2009 Just don't redline it all the time and you should be sorta fine. But I would probably wait until you go Stage 2 with DP and get a custom map. You would not see gains with Stage 1 with AVO Drop In Filter anyway. Mike has one for that setup so you probably don't even have to go protune. Link to comment Share on other sites More sharing options...
Heat Posted May 5, 2009 Author Share Posted May 5, 2009 I don't expect to see any gains stage 1 w avo versus stage 1 w/o avo. I just thought I'd be replacing the stock filter soon anyways, so might as well get the AVO. It may be a few months before I get the DP for stage 2. Link to comment Share on other sites More sharing options...
TPLGT Posted May 5, 2009 Share Posted May 5, 2009 You're fine w/a panel filter and no tune. No performance but sounds better. Rehab is for quitters. Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 5, 2009 Share Posted May 5, 2009 You'll be fine. Denial is your best friend Link to comment Share on other sites More sharing options...
Heat Posted May 5, 2009 Author Share Posted May 5, 2009 Thanks... I think "we" get a little dorky/absurdly paranoid on here at times. I suppose that's part of the fun. btw nice body G.T.Subie. Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 5, 2009 Share Posted May 5, 2009 Thanks... I think "we" get a little dorky/absurdly paranoid on here at times. I suppose that's part of the fun. btw nice body G.T.Subie. aww gee thanks Denial is your best friend Link to comment Share on other sites More sharing options...
