Brett Posted April 2, 2013 Share Posted April 2, 2013 so i just went in for my 90k mile check up and as usual i knew what to expect. i was a little surprised for a change. according to their inspection, i need transmission/diff oil that i just replaced last week. my drive belts and timing chain should be replaced (i still have time fo dat) and my cam seals are leaking? sounds like bs, but someone there would've fell for it. aside from the outrageous prices. for example, an alignment would cost $150!! so could you imagine the other prices? i even got a complimentary car wash... a hose down. thank you jones for taking the time out of my day to give me more reasons to never come back to you Link to comment Share on other sites More sharing options...
xero287 Posted April 2, 2013 Share Posted April 2, 2013 your cam seals are probably leaking around 90k. most people change them at 105k with the tbelt. Link to comment Share on other sites More sharing options...
Brett Posted April 3, 2013 Author Share Posted April 3, 2013 they wanted a thousand dollaz to do that! Link to comment Share on other sites More sharing options...
xero287 Posted April 3, 2013 Share Posted April 3, 2013 For just the cam seals or the t-belt and cam seals? That doesn't seem atypical for a dealer or similar. Go to Andrewtech, they'll hook you up for a cheap t-belt replacement. Link to comment Share on other sites More sharing options...
Brett Posted April 3, 2013 Author Share Posted April 3, 2013 both at once. i still have a few miles to go. Link to comment Share on other sites More sharing options...
xero287 Posted April 3, 2013 Share Posted April 3, 2013 Yeah, I wouldn't do CAM seals if you haven't done them before. The bolts were tightened by gorillas and they are tightened and loosened via a hex bolt. i.e. everything will strip or jump and you're screwed 3k. Link to comment Share on other sites More sharing options...
Brett Posted April 4, 2013 Author Share Posted April 4, 2013 i don't plan on diy. i'll pay to have it done right Link to comment Share on other sites More sharing options...
dplacen Posted April 8, 2013 Share Posted April 8, 2013 I used to work at Jones. It's the worse dealership I have worked for... Link to comment Share on other sites More sharing options...
Brett Posted April 8, 2013 Author Share Posted April 8, 2013 they also said that the transmission oil that i just replaced was bad... wtf? i'm pretty sure they burn up the clutch too when they drive your car, and joyride it Link to comment Share on other sites More sharing options...
