fiber_tek Posted January 6, 2011 Share Posted January 6, 2011 We bought a 95 Legacy a few months ago to save gas, previously spending $75 every 5 days in an Expedition. Anyway it has always started a little rough in the morning when cold, if you run the engine up to 2K for a few seconds it clears right up. But about a week ago we got a CEL and AutoZone said that it is P0420, Catalyst System Efficiency Below Threshold. Would this be plugged cats or an O2 sensor? Probably cheapest to try the O2 sensor then the cats. Can I gut the cats and run it(Montana, no emissions testing), and also how do I clear the CEL and see if it comes back? Thanks a million! Jason Link to comment Share on other sites More sharing options...
johnegg Posted January 6, 2011 Share Posted January 6, 2011 to clear the code you can disconnect the neg batery cable for ... over nite. that's way more than you neeed to do but it works. po420 could be the cats, but more likely the front o2 sensor. get one from a subaru dealer online, ~105$. (there have been some folks who used aftermarket o2s and it did not clear up the issue. when an oem o2 finally did.) you can gut the cat but why do it especially if it is working ok. it is not clogged, that would cause other issues. and if it fails and causes a code you can put an anti fouler on the rear o2 and be happy. even in a state with emissions. the front o2 sensor is used to adjust the fuel air ratio so you want it working, well. the rear o2 sensor just checks to see if the cat is there doing its job. it can throw a code if the cat is bad or missing but it does not effect how the car operates. so if the cat fails just put an anti- fouler on the rear o2. if it gets blocked, replace it with a straight pipe and add the anti-fouler. then just keep the car in montana. Link to comment Share on other sites More sharing options...
TaSe Posted January 12, 2011 Share Posted January 12, 2011 I work at a shop, P0420 = Catalytic Converter for sure. A bad O2 sensor could also throw the P0420 code as i've seen in some cars that come here, but more cases then others the catalytic will have to be replaced. Link to comment Share on other sites More sharing options...
fiber_tek Posted January 12, 2011 Author Share Posted January 12, 2011 Thanks for the input. The car also runs a little rich when started, clears up almost immediately, and it will periodically cut out while it is warming up. The colder it is outside the worse the cutting out gets. I am leaning towards a sensor, but if that doesn't fix it then I will certainly change the cat. Link to comment Share on other sites More sharing options...
fiber_tek Posted January 14, 2011 Author Share Posted January 14, 2011 The new OEM front O2 sensor fixed my problem so no need to replace the cats. Thanks for the help!! Link to comment Share on other sites More sharing options...
carnumber19 Posted January 14, 2011 Share Posted January 14, 2011 Seems like the problem was solved, but just to add to this thread I got the same code when I had a pretty large exhaust leak (read, manifold cracked 3/4 of the way around) right before the primary O2, a new manifold solved the problem. You would know for damn sure if you had that sized exhaust leak though. Link to comment Share on other sites More sharing options...
shwaldo Posted March 10, 2011 Share Posted March 10, 2011 I'm going through a similar issue now with my '05 legacy. Just replaced a front 02 sensor to clear code P0051. A week later, check engine light is back on and it's code P0420. I'm at about 71,000 miles, and the cats are under warranty to I think 80,000. I had the code cleared. If it comes back I'm heading straight to my dealer. Link to comment Share on other sites More sharing options...
johnegg Posted March 11, 2011 Share Posted March 11, 2011 Just replaced a front 02 sensor to clear code P0051. A week later, check engine light is back on and it's code P0420. did you use a subaru o2 sensor? it makes a huge difference for the front sensor, not so much for the rear. Link to comment Share on other sites More sharing options...
shwaldo Posted March 11, 2011 Share Posted March 11, 2011 I used a denso sensor, which is the oem for subaru. Link to comment Share on other sites More sharing options...
johnegg Posted March 11, 2011 Share Posted March 11, 2011 typically the p0420 code is a front sensor problem. since it showed up after the sensor was replaced that is probably the cause. there has been a HUGE discussion on another board about the difference in quality of OEM vs the manufacturer's non oem part. i don't know and wont go in to it but it is surprising how many times a subaru OEM o2 fixes the problem. did the o2 come wiht the connector on it or did you have to attache it? is the new connector plugged in completely? Link to comment Share on other sites More sharing options...
shwaldo Posted March 14, 2011 Share Posted March 14, 2011 It came with the connector. I'm pretty sure it's plugged in correctly, otherwise the original P0051 probably wouldn't have cleared. I didn't do it myself. As of today, the CEL hasn't come back on. It's been 4 days. and approx 120 miles. Link to comment Share on other sites More sharing options...
