haruichi808 Posted July 7, 2016 Share Posted July 7, 2016 Hi guys I ordered a half pint of rrp paint for my c mod and my faded plastic hood scoop. Just wanted to know the easy way to take those two off For the grill can I just take off the pop clips n pull out or does the bumper need to come out, and as for the hood scoop on my old legacy I could just pull it off ,is the 5th gen the same or do I need to unscrew something from under the hood? Link to comment Share on other sites More sharing options...
eckseleven Posted July 7, 2016 Share Posted July 7, 2016 The grill comes off easy. The clips like you mentioned on top plus a couple screws that are behind the grill on each side. It was a tight squeeze to get these but not too bad. Link to comment Share on other sites More sharing options...
foxrider28 Posted July 7, 2016 Share Posted July 7, 2016 Just took my grill off last weekend and it has 2 screws on each corner on the top going into the backside of the bumper cover and there are 2 more on the bottom that are center of the outer edge and middle of the grill. Not sure if those are still used on an aftermarket but I would assume so since thats all that holds the bottom of they grill in place. The top 2 can be easily gotten to with a regular phillips screwdriver but the bottom 2 eother need a "stubby" phillips or what I use is a 1/4" ratchet with 1/4" socket and a phillips bit. I found out it helps tremendously to take out the peice that the grill tabs snap into. As for the scoop insert that's on my to do list so I've not tackled that yet, but IIRC there are some screws holding it in place but I could be wrong. Edit: looked at the FSM and under, 10. Body Section (Book 2) > 7. Exterior-Interior Trim > 3. Hood Grille. I found the process to remove the "grille" which is what I assume is the insert peice. Here's a link to the PDF if you don't have a FSM handy. 3. Front Hood Grille.pdf https://drive.google.com/file/d/0B2wcN1xiWgjHVmlRaUhibUJJSk0/view?usp=drivesdk Link to comment Share on other sites More sharing options...
GTEASER Posted July 7, 2016 Share Posted July 7, 2016 I think the hood scoop has some one time use pop-its holding the splitter into the hood. You'll need to order some of those in order to reinstall it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jojorios Posted July 7, 2016 Share Posted July 7, 2016 I'm so happy you wrote that because I was planning on removing it this weekend. Guess I will hold off on that. Link to comment Share on other sites More sharing options...
foxrider28 Posted July 7, 2016 Share Posted July 7, 2016 Definitely has the one time use pop-its. Back in my body shop days we had tool set like this ( http://m.harborfreight.com/5-piece-upholstery-and-trim-tool-set-99739.html ) that would sometimes let you reuse those pop-its. Of course the set we used was from Snap-On so it was much nicer then the ones I linked. Biggest problem was if they broke which in most cases they did and then were a complete PITA especially the tiny ones. Link to comment Share on other sites More sharing options...
