boss755 Posted March 14, 2014 Share Posted March 14, 2014 hi i have a little worry here about my turbo, like a lot of LGT owners, and i want check the shaft play. So im thinking to unscrew the DP and go check, the car is mainly stock just got the AVO air fliter. So should a prepar a new gasket for the turbo to DP or i could just unscrew, check shaft play and screw it back ?? the car is LGT 2005 MT, i've had the car for 4 years now and i star to work on mechanic ( change brake, plugs ....) in the meant time i will check the banjo bolt and grease my starter, the turbo has whistled slightly since the begiining but now its seam like their is a stronger sound, little bit like i have install a CAI, (but i didint) it might just be the cold weather as well( -30 C ) but the car seem more powerful. So will i have trouble checking the SHaftplay or its easy and it will make me sleep better at night? Link to comment Share on other sites More sharing options...
bigleben Posted March 14, 2014 Share Posted March 14, 2014 Id say get another gasket as it will probably break into pieces if its the original gasket. If the bolts aren't too much rusted you'll be fine. And yes you will sleep better if the turbo is fine and even if its not as you will catch it before its too late. Feel free to pm if you have more questions Link to comment Share on other sites More sharing options...
boss755 Posted March 14, 2014 Author Share Posted March 14, 2014 alright tks for the advice, hopefully the bolts are not too rusty. but im pretty sure it will be fully corrode. Link to comment Share on other sites More sharing options...
bigleben Posted March 14, 2014 Share Posted March 14, 2014 LEt them soak in PB blaster over night Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2014 Share Posted March 14, 2014 Pick up new gaskets for both ends of the DP. You may want to get new bolts and nuts for the DP to mid pipe. just break the old ones or cut them off. Use lots of PB Blaster on all nuts and bolts. Use anti sieze on all nuts and bolts going back together. The heat shield may come off with a few broken bolts. Don't be to worried about that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boss755 Posted March 14, 2014 Author Share Posted March 14, 2014 mmm ok but i thought if i just disconnect the DP and turbo i would be able to put my fingers in and check the shaftplay. so you say that the DP wont move that much? Link to comment Share on other sites More sharing options...
bigleben Posted March 14, 2014 Share Posted March 14, 2014 You have to take off the DP to reach the turbine. The DP is attached to a bracket on the trans to prevent back/foward movement. Link to comment Share on other sites More sharing options...
boss755 Posted March 15, 2014 Author Share Posted March 15, 2014 Ok . i will start to work on that this week . after i shuffle 6feet of snow in front of my garage. Link to comment Share on other sites More sharing options...
