shirekid2.5i Posted November 1, 2013 Share Posted November 1, 2013 ok so hears the deal, i drive a 2008 outback LLBean H6 with the 5eat. Last weekend i replaced my drivers side front axle due to a bad inner boot. Ever since then, I've noticed that every time i take off from a stop, somewhere around 15 mph until about 20, the car shakes like its got a bad cv joint. The thing is, it feels like its coming from the center of the car. Also, it seems to not matter what gear I have it in (using tiptronic), and will only do it when i have a load on the drivetrain, aka on the gas at all, if i let off, or coast, it stops. I'm stumped at the moment on what it could be. Part of me is leaning toward the driveshaft u joint, or maybe something to do with the d.s. center carrier. The main reason i think it could be the carrier is, earlier after work, i got under the car and tried to see if the shaft had any unusual play to it, and it moves around quite a bit in the carrier in all directions, except front to rear, which seems unusual to me. Just wondering if anybody else has run into anything like this, or has any other ideas what it could be. Any help/input would be greatly appreciated. thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2013 Share Posted November 1, 2013 Put another new axle in, IMO you have a bad one. BTW I didn't even finish reading your post. Axles are a crap shoot.... It should be covered by the auto parts store. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted November 1, 2013 Share Posted November 1, 2013 Put another new axle in, IMO you have a bad one. BTW I didn't even finish reading your post. Axles are a crap shoot.... It should be covered by the auto parts store. This Link to comment Share on other sites More sharing options...
shirekid2.5i Posted November 1, 2013 Author Share Posted November 1, 2013 i was sort of thinking that, it was a new one, not a re-manufactured one so i thought itd be ok. ill definitely look into it though. it does make sense considering i didnt notice the shake till i changed it. thanks for the advice Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2013 Share Posted November 1, 2013 This past summer I had my mechanic do a bunch of work, one was to replace the axle I replaced 4 years ago. With all he told me about what he did, I remember he said he had to put two axles in, the first one he got was doing the same thing your is. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 2, 2013 Share Posted November 2, 2013 If it didn't shake BEFORE you put the axle in, and it shakes AFTER you put the axle in, my guess would be AXLE. Link to comment Share on other sites More sharing options...
