SCCA GT Posted May 9, 2015 Share Posted May 9, 2015 I like the 3.70 gears it's so nice on road trips . Everything work like it should but no cruise control . I checked for trouble codes . The cruise light will light up just won't set . Does anyone have anything I can try or look for. Thanks this is 5spd manual GT wagon Link to comment Share on other sites More sharing options...
rhino6303 Posted May 10, 2015 Share Posted May 10, 2015 Did you swap your neutral safety switch from the old transmission? There were two types subaru used. On one, the switch is "on" when pushed in and the other type is opposite. Cruise will not set when the wrong type of switch is used. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 10, 2015 Share Posted May 10, 2015 ^^^Did not know that...Good information. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 10, 2015 Share Posted May 10, 2015 Did you swap your neutral safety switch from the old transmission? There were two types subaru used. On one, the switch is "on" when pushed in and the other type is opposite. Cruise will not set when the wrong type of switch is used. This^^^^ You can test to see if it's the switch. Run the car above 30mph & put the MT in N & then try to set you cruise. If it "set". You need the NSS for the car you installed the MT in. Not from the car MT come out of. So the ECU gets the right signal from the MT. I came across this when I did my 5MT (LGT) to 6MT(STi) swap. Cruise will set in N, but not in gear. Until I installed the NSS for the LGT 5MT in the STi 6MT. Then my cruise worked correctly. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
SCCA GT Posted May 10, 2015 Author Share Posted May 10, 2015 Thanks for the info . I used the one from the 06 wrx it looked the same with the same plug . I will let you know .Thanks again Link to comment Share on other sites More sharing options...
SCCA GT Posted May 12, 2015 Author Share Posted May 12, 2015 That fix it Thanks for the Help Link to comment Share on other sites More sharing options...
rhino6303 Posted May 12, 2015 Share Posted May 12, 2015 That fix it Thanks for the Help No problem. Glad it worked. Link to comment Share on other sites More sharing options...
