subaruski Posted July 17, 2009 Share Posted July 17, 2009 Just bought a Cobb Uppipe that has a bung for the EGT in it. I know must people would just say plug it but what are the benefits if I run the sensor? Just help log with the AP? Link to comment Share on other sites More sharing options...
whitetiger Posted July 17, 2009 Share Posted July 17, 2009 dont need it. just plug the hole. Link to comment Share on other sites More sharing options...
mightyS Posted July 17, 2009 Share Posted July 17, 2009 Don't need it. My car now has the STi up pipe. There is no hole for the EGT. Here is a link to add a resistor so you don't get engine check lights: http://www.clubwrx.net/forums/maintenance-service-repair/58505-egt-cel-fix-after-installing-uppipe.html Link to comment Share on other sites More sharing options...
subaruski Posted July 17, 2009 Author Share Posted July 17, 2009 size of bolt to plug it? Link to comment Share on other sites More sharing options...
highspeed11 Posted July 18, 2009 Share Posted July 18, 2009 M12X1.25 I believe. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 18, 2009 Share Posted July 18, 2009 The EGT sensors soul purpose in life is to monitor the temp of the Catalytic converter in the up pipe. If you don't have a cat, you don't need the sensor. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
subaruski Posted July 18, 2009 Author Share Posted July 18, 2009 any foreseen problems if I leave the sensor in? Link to comment Share on other sites More sharing options...
highspeed11 Posted July 19, 2009 Share Posted July 19, 2009 I just replaced my uppipe with a stock STI pipe which of course does not have the bung. I used a 2.2k ohm resistor in the connector and covered with tape. I was weary about not using the EGT sensor in an aftermarket pipe but after plenty of reading I'm satisfied that it is unnecessary. The unforeseen problem I guess would be that the sensor somehow breaks off and damages your turbo. Unlikely but possible. Link to comment Share on other sites More sharing options...
ABP_Tardis_42 Posted July 19, 2009 Share Posted July 19, 2009 From what I have read pre 07 had catted uppipes, so presumably you would want one with the bung. Basically to either throw the O2 sensor in there or an exhaust temp sensor for the gauge if you are going to install one. I just put the GReddy pipe on mine last Friday with the bung and no problems so far, but there are also other drivers that are running bungless with no problems. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 19, 2009 Share Posted July 19, 2009 any foreseen problems if I leave the sensor in? The sensor can melt and get sucked into the turbo. It happens more then you'd think My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted July 19, 2009 Share Posted July 19, 2009 The sensor can melt and get sucked into the turbo. It happens more then you'd think Links to such events ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Spec B Posted July 19, 2009 Share Posted July 19, 2009 Is the stock EGT of any value in monitoring EGTs during tuning? I thought it was and that is why I left it in my gutted stock DP. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 19, 2009 Share Posted July 19, 2009 You'll only see a few recorded events of melted EGT sensors on the the interwebs because it mostly happens to stock cars or lightly modified ones. The people that don't visit forums. The people on the forums usually remove the EGT fairly quickly. You're also gonna hear less and less because all new turbo subarus DON'T come with one. The Stock EGT sensor could be useful for tunning, if it wouldn't fry so quickly. They're not meant for the higher temps we create when we mod the car. They burn up pretty easily. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
NSFW Posted July 20, 2009 Share Posted July 20, 2009 I just replaced my uppipe with a stock STI pipe which of course does not have the bung. I used a 2.2k ohm resistor in the connector and covered with tape. What temperature does the ECU think your exhaust is? I wonder what the ECU uses the temperature information for... my only guess is that it varies AFRs to achieve some particular EGT during idle and/or cruise, and I'm a little leery of putting in a fixed resistor without knowing what the ECU is going to do in response. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 20, 2009 Share Posted July 20, 2009 The ecu uses EGT temp for one of the 10 million OL/CL transition delay tables and for simply a high or low temp alarm. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
NSFW Posted July 20, 2009 Share Posted July 20, 2009 You'll only see a few recorded events of melted EGT sensors on the the interwebs because it mostly happens to stock cars or lightly modified ones. The people that don't visit forums. How did you come across information about these failures? Link to comment Share on other sites More sharing options...
PhilT Posted July 20, 2009 Share Posted July 20, 2009 What temperature does the ECU think your exhaust is? I wonder what the ECU uses the temperature information for... my only guess is that it varies AFRs to achieve some particular EGT during idle and/or cruise, and I'm a little leery of putting in a fixed resistor without knowing what the ECU is going to do in response. I remember seeing a temperature of around 600F with the resistor installed. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted July 20, 2009 Share Posted July 20, 2009 How did you come across information about these failures? I work in the industry it's a little more common than plugged cats...which we hear about ALL the time My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted July 21, 2009 Share Posted July 21, 2009 I work in the industry it's a little more common than plugged cats...which we hear about ALL the time What do you do in "The Industry" ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
subaruski Posted July 21, 2009 Author Share Posted July 21, 2009 What do you do in "The Industry" ? He unplugs cats and changes EGT sensors.... duh:lol: Link to comment Share on other sites More sharing options...
HarryN Posted August 13, 2009 Share Posted August 13, 2009 Hello, my friend and I were having a discussion about my car. It is a 2009 LGT Limited. He says that my car needs an EGT sensor on my uppipe and says that my uppipe has an EGT sensor. He says that if I don't have it, my car will throw up CEL errors all over the place. Is this fact or fiction? I used the search function on the forums and could not see anything about an EGT sensor on my 09 LGT. I would appreciate insight as well, about EGT sensors and why my car will throw cells all over the place if I don't have one. Link to comment Share on other sites More sharing options...
NSFW Posted August 13, 2009 Share Posted August 13, 2009 I've heard that only the cars with catted UPs have EGTs, but I own an 05 so haven't had a change to verify that. If that's accurate, your 09 wouldn't have one. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 13, 2009 Share Posted August 13, 2009 09 doesn't have one My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
SATSFYD Posted August 17, 2009 Share Posted August 17, 2009 I just replaced my uppipe with a stock STI pipe which of course does not have the bung. I used a 2.2k ohm resistor in the connector and covered with tape. I was weary about not using the EGT sensor in an aftermarket pipe but after plenty of reading I'm satisfied that it is unnecessary. The unforeseen problem I guess would be that the sensor somehow breaks off and damages your turbo. Unlikely but possible. How long have you had this set up and have you seen any problems with it? **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
highspeed11 Posted August 18, 2009 Share Posted August 18, 2009 I replaced it about a month ago and have put 2000ish miles on it. No problems at all and I have the added peace of mind that there isn't a cat that can fall apart and damage my turbo. I paid $60 for the Sti pipe. I reused the old gaskets but I would recommend that you replace them with new Subaru gaskets. Link to comment Share on other sites More sharing options...
