stealitall Posted February 9, 2014 Share Posted February 9, 2014 I will be replacing my old Konis and springs . So I was fingering since the top hats have about 140k on them I should replace them as well. So should I replace with stock or upgrade them. I've replace my lower arm bushing with AVO + 0.50 and I noted that most upgrade Top Hats change the caster and camber and didn't know if it would throw it off to much. PS. I don't have the best grammar LOL Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2014 Share Posted February 9, 2014 I believe most us use OEM top hat's. I did for the Konis and Epic's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
