jblackwell1 Posted January 12, 2012 Share Posted January 12, 2012 Im looking for where the grounds in the engine bay go on the drivers side. You should be able to see where they are by simply removing the engine cover. I think they ground to the very back on the top of the drivers side head but would like confirmation on that. If anyone can look at their car and let me know id apprciate it. The wires come out of the main wire run with the injectors and the grounds are square ground rings. Any help would be great. Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 12, 2012 Author Share Posted January 12, 2012 bump for some help. Link to comment Share on other sites More sharing options...
frank_ster Posted January 12, 2012 Share Posted January 12, 2012 there is a peice of aluminulm back there i think its part of the tgv valve things with two threaded holes vertically in there. and the starter had also a large ground going to one of its mounting bolts. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
GTTuner Posted January 12, 2012 Share Posted January 12, 2012 Yes, driver side at the back of the head, there are two 8x1.25 mm bolt attaching two seperate grounds. They are buried under there so you need to dig deep. Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 thanks guys, tgv deletes didnt include that bracket and i didnt have my old ones, but i got it so were good to go. thanks for the help. Link to comment Share on other sites More sharing options...
