DMTaylor Posted December 23, 2011 Share Posted December 23, 2011 Driver's front hit pretty hard. Hard enough to break the hat off the rotor! Got new rotor, but now the rest of the damage is becoming more apparent. The knuckle/bearing assembly is definitely bent. So my question is: Is the assembly the same for all 05-09 Legacy's? Regardless of turbo/non-turbo/Spec B? Link to comment Share on other sites More sharing options...
Code Posted December 23, 2011 Share Posted December 23, 2011 Depending on how extensive the suspension damage is, most parts are the same. Spec beeee LCA were aluminum, they used different dampers and top hats than gt and 2.5i "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
DMTaylor Posted December 24, 2011 Author Share Posted December 24, 2011 Thanks Code The LCA seems to be ok, comparing shape with the passenger side. I guess I will just replace the bearing/hub assembly for now and see if that fixes the issue. Link to comment Share on other sites More sharing options...
