gfxdave99 Posted June 18, 2010 Share Posted June 18, 2010 So I have been surfing around and found http://powerbastards.com/proddetail.asp?prod=Fitzall-220 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220483165753&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=e01321a41280a03662a57a65ffecbc94&rvr_id=&ua=WXF%3F&itemid=220483165753 http://www.maniacelectricmotors.com/11058hiamp.html any personal experience with any of these? :spin: If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
gfxdave99 Posted June 24, 2010 Author Share Posted June 24, 2010 nothin? Really? If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
m sprank Posted June 24, 2010 Share Posted June 24, 2010 I have used the maniac motors 140amp alternator for 1 year with no issues. Solved my low voltage supply issue. Link to comment Share on other sites More sharing options...
gfxdave99 Posted June 24, 2010 Author Share Posted June 24, 2010 I have used the maniac motors 140amp alternator for 1 year with no issues. Solved my low voltage supply issue. Thanks! I just wanted to know somebody used one without issue heh. For 182 with core return its a good deal compared to some of the crazy $400 and up ones ive seen If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
m sprank Posted June 24, 2010 Share Posted June 24, 2010 Yes it is. It is direct drop in too. I also have a 225amp alt from a BIG name company (on the SpecB the maniac is on the 5EAT). Had to grind the every loving s*** out of the mount to make it fit. I am very happy with the performance and reliability of the maniac motors alt. Especially for the money. Link to comment Share on other sites More sharing options...
lil_z_33 Posted June 26, 2010 Share Posted June 26, 2010 m_sprank, are both upgraded alternators you have the same dimensions as stock? I am going to be doing a rotated manifold setup, but need a bigger alternator as the stock one cannot supply the power needed for my stereo... Link to comment Share on other sites More sharing options...
m sprank Posted June 26, 2010 Share Posted June 26, 2010 Maniac motors is an OEM housing with new guts. Pure drop in replacement. The other I have is not an OEM housing. Basically the same size. But takes a special bracket (supplied) and a lot of grinding on the OEM mount (A/C compressor side) to make it fit. Link to comment Share on other sites More sharing options...
cootz Posted June 27, 2010 Share Posted June 27, 2010 m sprank and gfxdave....what battery are you using under the hood? I am in the middle of this alternator/battery issue too (getting system installed soon with about 1500 watts total). Seems like everyone has a different opinion and personal preference on batteries. The audio shop said a yellow-top would be fine..but there are also others I could look into. I think i will do a big 3 and battery upgrade and hold off on the alt...hopefully i will be fine. I dont plan on using an additional battery in the trunk either. Link to comment Share on other sites More sharing options...
m sprank Posted June 27, 2010 Share Posted June 27, 2010 Stock, OEM. The one that came with the car. Battery is only used to start the car. Alternator takes over from there. I dont turn system on with car not running, so I have no fear of draining the battery. This is my 220 amp I just got for the SpecB. http://mechman.com/store/product_info.php/cPath/8_3231_3232_3233/products_id/391 I paid about half that price. But found it from another member. Link to comment Share on other sites More sharing options...
Nuclear Posted February 2, 2017 Share Posted February 2, 2017 Interesting upgrade kit for OEM 80A alternator (partnumber # 23700-AA520), i think after using it we will get 110A (waiting answer from ManiacElectricMotors): http://www.maniacelectricmotors.com/alternator-rebuild-kit-2006-2010-impreza-2006-2010-forester-2005-legacy-2005-outback.html People from ManiacElectricMotors answered me, that OEM partnumber # 23700-AA520 is 110A ufffff Link to comment Share on other sites More sharing options...
Nuclear Posted February 2, 2017 Share Posted February 2, 2017 Good new and rebuild products from WAI Global: http://www.waiglobal.com/partsearch/?query=23700-AA520 Link to comment Share on other sites More sharing options...
stevenva Posted February 3, 2017 Share Posted February 3, 2017 DC Power Engineering. I have a 180A one. Been solid past 6 years. Blue anodized. My 96 Legacy lost reverse. Want to buy it. Wont fit in my 05 Bean. EDIT. I don't think it would work in yours if it's an H6 http://i472.photobucket.com/albums/rr85/smstavros/P1000831.jpg http://i472.photobucket.com/albums/rr85/smstavros/P1000832.jpg http://i472.photobucket.com/albums/rr85/smstavros/P1000833.jpg RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
stevenva Posted February 3, 2017 Share Posted February 3, 2017 Back to the very beginning of your power issue.. After doing capacitors and alternators with many 12 volt systems, It's always THE BIG 3 upgrade that has made the biggest difference. With my newer car, the 05 Bean, all I did was THE BIG 3 upgrade and I'm very satisfied with the results. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
