InvisibleFrisbee Posted January 28, 2013 Share Posted January 28, 2013 I purchased my 08 LGT spec.B about a month ago and it was 100% stock. I am jumping into learning to tune my car, and after reading some documents on how to tune it was time to make it practical and decided to use this base tune as a starting point. I registered over there, but don't yet have posting privileges on romraider, so I thought I'd look for some feedback here. I logged a some on the stock ROM first to compare to this ROM, then copied the tables over to my stock ROM and loaded it to the car. I've included the log file of some pulls including a 3rd gear pull, others of regular driving were to large to upload here. Here are the vitals I think you need on my car (let me know if you need more). 2008 Legacy spec.B (A2TB000L) Hogzaust is the ONLY mod 93 Octane fuel, 10% ethanol 32F outside according to Nav. One thing of concern is that Manifold Relative Pressure (psi) remained at zero in both the stock and this base ROM. I'm assuming that is a problem, but hoping that you guys can confirm that. I'd appreciate any feedback that you can give me on these logs.romraiderlog_20130126_213006.csv Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted January 28, 2013 Share Posted January 28, 2013 Check the lines going to the MAP sensor. It is located by your turbo inlet on the front of the manifold. The nipple for it goes straight down but check all the lines around there. Also, read this: http://www.romraider.com/forum/viewtopic.php?f=33&t=5384 . From our very own NSFW. Link to comment Share on other sites More sharing options...
InvisibleFrisbee Posted January 29, 2013 Author Share Posted January 29, 2013 Everything looks hooked up properly with the MAP sensor, the vac hose leading over to the sensor is in tact and the sensor itself is hooked up. I pulled the connector and re-seated just in case. Should the map sensor read vacuum at idle? Or will it only read positive pressure? I haven't reset the ECU yet to test if reseating the connector did anything, but assuming it does nothing, how do I test the MAP sensor to see if it is bad? Link to comment Share on other sites More sharing options...
InvisibleFrisbee Posted January 29, 2013 Author Share Posted January 29, 2013 Ok, I found my boost leak, a line had popped off. zip tied it back on and the MAP sensor registers now. FYI, in case others are interested in the future, the MAP sensor does register a vacuum if it is connected, so a flat zero is a bad sign. Link to comment Share on other sites More sharing options...
ehsnils Posted January 29, 2013 Share Posted January 29, 2013 OK, time for a new set of logs then! Link to comment Share on other sites More sharing options...
bigjweb Posted January 29, 2013 Share Posted January 29, 2013 I'm not a tuner but shouldn't there be more info about the fuel trims and AFR? Link to comment Share on other sites More sharing options...
InvisibleFrisbee Posted January 29, 2013 Author Share Posted January 29, 2013 Here is the new log. I'm going to adjust what I log based on the above link, but what was logged here is specifically what the creator of the ROM requested. 64F outside for this log.romraiderlog_20130128_221621.csv Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 1, 2013 Share Posted February 1, 2013 Try logging the following: Accelerator Pedal Angle (%) Engine Load (1-byte)** (g/rev) Engine Speed (rpm) Feedback Knock Correction (1-byte)** (degrees) Fine Learning Knock Correction (1-byte)** (degrees) IAM (multiplier) Ignition Total Timing (degrees) Manifold Relative Pressure (Corrected) (psi) Mass Airflow (g/s) Primary Wastegate Duty Cycle (%) Requested Torque* (raw ecu value) Log a few WOT pulls. If you are using the 91 octane map, your timing should be conservative enough to not pull much, if any, timing (might need to add a bit, depending on the logs). I personally do not log knock count because of false knock counts at low loads. keep an eye or your feedback and fine learning knock info. Make sure your IAM is at 1 before doing your WOT pulls. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 1, 2013 Share Posted February 1, 2013 After a bit of driving, check your learned fuel afr's, make sure you're not off on your maf scaling www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
