G5892 Posted June 24, 2014 Share Posted June 24, 2014 Can someone help me out real quick? Does the coolant cap with the "ears" go on the coolant reservoir by the turbo, or on the radiator? I believe one is measured 108 and the other 137. Thanks. I checked the manual but couldnt find anything. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2014 Share Posted June 24, 2014 I think they will only go on one way. I replaced both mine a while back. they are different and one go one way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2014 Share Posted June 24, 2014 Just walked out and checked ears on the tank by the turbo. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Gex Posted June 24, 2014 Share Posted June 24, 2014 108kpa on turbo reservoir 137kpa on radiator. Link to comment Share on other sites More sharing options...
G5892 Posted June 24, 2014 Author Share Posted June 24, 2014 Thanks guys. Just making sure I had them on right. Link to comment Share on other sites More sharing options...
