lee07 Posted December 9, 2011 Share Posted December 9, 2011 Bought Peak Long Life "Full Strength" Coolant(2 gallons). Now does this need to get mixed with water or can I just pour/use it right away? If it needs water then I only need one gallon, right? This coolant should be fine to use on the car? Link to comment Share on other sites More sharing options...
frank_ster Posted December 9, 2011 Share Posted December 9, 2011 pure concentration of coolant can cause the hoses to deteriate. your "supposed to " use distilled water. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
compsurge Posted December 9, 2011 Share Posted December 9, 2011 Someone had posted in another thread at one point that Peak is the OE for Subaru coolant and that the long life is identical to Subaru coolant. That being said, I know several folk on here run whatever is cheapest and have no ill effects. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 9, 2011 Share Posted December 9, 2011 My 05 has had Prestone in it since I did the timing belt at 95,000 miles. I bought one gallon and mixed it 50/50 with tap water. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted December 9, 2011 Share Posted December 9, 2011 read the container Link to comment Share on other sites More sharing options...
lee07 Posted December 10, 2011 Author Share Posted December 10, 2011 O.k I went and exchanged it for the 50/50 coolant. It says it's good for 5 years. Now should I believe this or change it every 2-3 years like always? Link to comment Share on other sites More sharing options...
iceberg385 Posted December 10, 2011 Share Posted December 10, 2011 it doesnt hurt to change every 3 years Link to comment Share on other sites More sharing options...
pillboy Posted December 10, 2011 Share Posted December 10, 2011 Too bad rao doesn't subscribe to coolant threads too. It is still ugly. Link to comment Share on other sites More sharing options...
outahere Posted December 10, 2011 Share Posted December 10, 2011 Someone had posted in another thread at one point that Peak is the OE for Subaru coolant and that the long life is identical to Subaru coolant......... I really doubt the truth of that statement. What I wrote in the maintenance sticky: Some new asian formula coolants are available from Beck Arnley: Extended Life Blue (for Subaru) Extended Life Pink Red Concentrate Green Concentrate (for Subaru) http://www.beckarnley.com/bafluids.html Subaru owners now have a choice of 5 different asian formula coolants, 2 from Subaru, 2 from Beck Arnley, and 1 from Zerex. Link to comment Share on other sites More sharing options...
burnout8488 Posted December 11, 2011 Share Posted December 11, 2011 O.k I went and exchanged it for the 50/50 coolant. It says it's good for 5 years. Now should I believe this or change it every 2-3 years like always? Why didn't you just return one gallon and turn it into 50/50? Premixed 50/50 costs more per gallon. Link to comment Share on other sites More sharing options...
ericem Posted December 11, 2011 Share Posted December 11, 2011 why didn't you all just go to the dealer and grab subaru long life for under $20 a gallon . Link to comment Share on other sites More sharing options...
rao Posted December 12, 2011 Share Posted December 12, 2011 Subscribed Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2011 Share Posted December 12, 2011 O.k I went and exchanged it for the 50/50 coolant. It says it's good for 5 years. Now should I believe this or change it every 2-3 years like always? it doesnt hurt to change every 3 years At this point in the cars life, you'll most likely have some reason that will cause you to have to replace the coolant anyway's in 3 years. Or you will no longer have the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2011 Share Posted December 12, 2011 I really doubt the truth of that statement. What I wrote in the maintenance sticky: Some new asian formula coolants are available from Beck Arnley: Extended Life Blue (for Subaru) Extended Life Pink Red Concentrate Green Concentrate (for Subaru) http://www.beckarnley.com/bafluids.html Subaru owners now have a choice of 5 different asian formula coolants, 2 from Subaru, 2 from Beck Arnley, and 1 from Zerex. Let not forget about good old Prestone green, buy the one gallon bottle and mix it 50/50 with water. You can buy distilled water from walmart or just fill a gallon milk jug with tap water and let it sit with the top off for a couple of day's and use it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dbl_D718 Posted December 13, 2011 Share Posted December 13, 2011 just fill a gallon milk jug with tap water and let it sit with the top off for a couple of day's and use it. That's not at all how distilling works. That would make the impurities more concentrated, if anything, as some of the water evaporates. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
burnout8488 Posted December 13, 2011 Share Posted December 13, 2011 It would evaporate the chlorine! Link to comment Share on other sites More sharing options...
liljonson Posted December 13, 2011 Share Posted December 13, 2011 psssshhh coolant is one of the first things i got rid of when i got my car..... I use Toyota long life because i get that junk for free. Any coolant would work, just get 50/50 premixed so you don't have to worry about distilled waters and stuff. Link to comment Share on other sites More sharing options...
