theGeneral Posted September 16, 2012 Share Posted September 16, 2012 I searched and could not find a thread listing what people have paid to have their front wheel bearings. Either the search feature sucks on this site or there are no threads on this subject. So, I started a thread about it. My left front wheel bearing went. I took my car to KOST Tire and Muffler because they have done good work for me in the past. They charged me $268.63 for the parts. And 124.60 labor. Since this is a pretty common problem on our cars I am interested what other people got charged, hopefully I was not raped to bad. After the job I was thinking about the fact that I paid for an extended service plan from the dealer when I bought the car. Dunno if it would have covered this.....I guess if it did I am a moron for not going to the dealer. (don't tell my wife). Link to comment Share on other sites More sharing options...
Mill Posted September 17, 2012 Share Posted September 17, 2012 I dont think that is too bad. I paid $160 for my Timken rears. Installed them myself though. In the end it would have been cheaper to have a shop do it after I broke the ABS sensor and CV shaft. Front wheel bearings are usually a bit pricier, so I say you got off fair. edit: Misread. That is way overpriced for one side. I read it as both sides at first. Link to comment Share on other sites More sharing options...
ericem Posted September 17, 2012 Share Posted September 17, 2012 isnt the front bearing assembly from the dealer only like $150 and yes ill bet it would have been covered under warranty. How many miles just curious? Link to comment Share on other sites More sharing options...
compsurge Posted September 17, 2012 Share Posted September 17, 2012 That's a lot of money for a 1 hour job and $130 part. Don't sweat it though. Hopefully they replaced it with the OEM Subaru part and not a third party one. Link to comment Share on other sites More sharing options...
whitetiger Posted September 17, 2012 Share Posted September 17, 2012 FYI, if you are comfortable with basic tools, the front hub/bearings can be done by yourself. Link to comment Share on other sites More sharing options...
SBT Posted September 17, 2012 Share Posted September 17, 2012 Seems a bit high for one - I thought it was for both fronts too. Unless something else was replaced, can't see where there was more than $130.00 in parts for an OEM hub bearing assembly and the axle nut. Add an hour in for labor, and you should be looking at ~$225.00 out the door. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Danteneon Posted September 17, 2012 Share Posted September 17, 2012 You were overcharged for the part. 28373AG01A...HUB UNIT..MSRP $169.95 902170049.....NUT.........MSRP $5.40 I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
compsurge Posted September 17, 2012 Share Posted September 17, 2012 FYI, if you are comfortable with basic tools, the front hub/bearings can be done by yourself. So long as basic tools includes an impact gun for the axle nut (I had no problems with my corded DeWalt 350 ft-lb electric impact). Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2012 Share Posted September 17, 2012 Or...A 3ft pipe on the 1/2" breaker bar with the 32mm or 1 1/4" socket on it. Have someone step on the brake pedal while you push on the pipe. You may want to open the pined over part of the axle nut too. I had no problem with any of the 4 hub bolts. They all came free pretty easy. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
theGeneral Posted September 17, 2012 Author Share Posted September 17, 2012 You were overcharged for the part. 28373AG01A...HUB UNIT..MSRP $169.95 902170049.....NUT.........MSRP $5.40 That is the part for the GT, I have a 2008 2.5i Limited. So....I just called them and the guy said that the part cost them $98 and that they mark it up 2.5%! I am going to call the general manager tomorrow. Danteneon, do you have the part number for my car? Link to comment Share on other sites More sharing options...
Danteneon Posted September 18, 2012 Share Posted September 18, 2012 The part number I posted is for all 2008 Legacy and Outback (other years as well). If they are saying that they paid $98.00 for the part, then that tells me they did not use a factory part either. No dealer is going to sell a factory part below cost I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
SBT Posted September 18, 2012 Share Posted September 18, 2012 Yes - at those prices I would expect (and demand) Subaru factory OEM parts, not an aftermarket OEM-quality part. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
compsurge Posted September 18, 2012 Share Posted September 18, 2012 I'd abuse cruise control to make sure it still functions properly. If it isn't, they need to replace it with an OEM unit. Link to comment Share on other sites More sharing options...
BGPKR Posted September 19, 2012 Share Posted September 19, 2012 I paid $108 shipped for the front Timken bearing and $48 labor to install... Link to comment Share on other sites More sharing options...
