rexster Posted November 8, 2006 Share Posted November 8, 2006 I've been reading lots of threads about wagon setups. I'm looking for something that is better than stock, not harsh, and only lowers a little. From what I've read I think pairing the (soon to be released) Koni inserts with JDM Spec B (GT-B) springs (not the pinks) with USMD struts and Koni inserts (& USDM top hats) would be a great setup. The front would be lowered about 1/2 inch due to slightly shorter JDM springs, the rear would have a slight drop (maybe 1/8 inch). The best part is the non-pink springs are cheaper, they'll be free anyway with some suby bucks. So, for the price of Koni inserts this should be a decent wagon setup that won't sacrifice ride quality and should allow for hauling stuff. It would be very similar to running JDM Spec B Bilsteins except it will be a little lower up front, it will cost less, and it will add some adjustability. What do the experts think? Link to comment Share on other sites More sharing options...
lhsa Posted November 9, 2006 Share Posted November 9, 2006 how can anyone respond when the koni's are still vaporware? Link to comment Share on other sites More sharing options...
rexster Posted November 9, 2006 Author Share Posted November 9, 2006 I'm not asking if anyone has already done it. I guess I was just thinking out loud and wondering if anyone else could think of a reason why this wouldn't work. Link to comment Share on other sites More sharing options...
PGT Posted November 9, 2006 Share Posted November 9, 2006 how can anyone respond when the koni's are still vaporware? because a member has a prototype set mounted and is quite please with them. I feel the JDM Spec B springs are a bit firm (as did Japanese buyers) - you'd have to do Rev. B or later to make this work properly. Link to comment Share on other sites More sharing options...
Max Rebo Posted November 9, 2006 Share Posted November 9, 2006 I feel the JDM Spec B springs are a bit firm (as did Japanese buyers) - you'd have to do Rev. B or later to make this work properly. I'll have this setup around the end of the year (JDM specB pinks + JDM specB Rev.C Bilsteins). Unclemat has a similar setup... perhaps different springs, but he has Rev.B Bilsteins. I'll do a full write-up after the install. Hopefully I will search no more after this! I sort of wish that we could buy a proper sport suspension, STi or otherwise, at the dealer. They have suspension upgrades for the WRX, but not the Legacy. Link to comment Share on other sites More sharing options...
lhsa Posted November 9, 2006 Share Posted November 9, 2006 so one guy tested them on his car without the specB springs. how can you comment on the setup? it's pure speculation. no one even knows when the inserts will be available. because a member has a prototype set mounted and is quite please with them. I feel the JDM Spec B springs are a bit firm (as did Japanese buyers) - you'd have to do Rev. B or later to make this work properly. Link to comment Share on other sites More sharing options...
PGT Posted November 9, 2006 Share Posted November 9, 2006 but, he's asking for speculative opinions here...based on what we know so far. Link to comment Share on other sites More sharing options...
Max Rebo Posted November 9, 2006 Share Posted November 9, 2006 but, he's asking for speculative opinions here...based on what we know so far. Ah... right. Well, in that case, I think the OP's idea will work great! /no idea... Link to comment Share on other sites More sharing options...
rexster Posted November 10, 2006 Author Share Posted November 10, 2006 I feel the JDM Spec B springs are a bit firm (as did Japanese buyers) - you'd have to do Rev. B or later to make this work properly. That's one of my concerns. Does anyone know the spring rates for the various GT springs (stock US, JDM GT, JDM GT-B)? I've tried searching and found all kinds conflicting information but wasn't able to find anything conclusive. If I can get the spring rates, maybe I can get an opinion from Koni once the inserts are out. Plus I know the GT Konis are going to be similar to the impreza ones and I know of several springs (along with their rates) that work well with the konis on the impreza. Link to comment Share on other sites More sharing options...
Guest Posted November 10, 2006 Share Posted November 10, 2006 JDM SpecB Bilsteins Rev. B with SpecB Pinks are great. Sure on the aggresive side, but nowhere uncomfortable. You must be a wimp to not like setup like this. My wife/kids don't complain. Actually my wife likes the setup better than JDM GT I had before. Pinks are 222/336 lbs/inch front/rear (about 4/6 kg/mm). AFAIK (may not be reliable info) JDM SpecB OEM springs have same rates. As far as harshness of JDM SpecB Rev.A goes - it's the dampers, not springs AFAIK. Link to comment Share on other sites More sharing options...
