Heytiggr Posted January 11, 2008 Share Posted January 11, 2008 I am loving my car and just about everything about it. One thing that is irritating me though is Subaru has made a decision for me regarding when I want my moonroof shade to close. As you may know, if you open the sunroof as far as the shade is open, when you close the moonroof, the shade is pulled closed along with it. Does anyone know where the catch is that hooks them together and how to cleanly make it go away? My shade stays closed when I want it closed or even partially open/closed. I don't have any of those type of problems I have seen described on the forums. I just want to be the one that decides when I close the shade. I don't need my car doing it for me just becasue i opened the glass as far as the shade. Thanks. Link to comment Share on other sites More sharing options...
Heytiggr Posted January 12, 2008 Author Share Posted January 12, 2008 Well, when you are tall with long arms like me, it's not a tough reach. Besides they have it so even if I don't open the shade all the way, if I open the glass to where the shade is, it pulls the shade closed when I close the glass. Then I have to wait for it to be all the way closed before I can slide the shade back open again. There has to be a way to disable or disconnect that! Link to comment Share on other sites More sharing options...
Spanky Posted January 14, 2008 Share Posted January 14, 2008 +1 sooooo annoying! Link to comment Share on other sites More sharing options...
Kelvrick Posted January 16, 2008 Share Posted January 16, 2008 Screw that, I want one touch close. Why do I have to press the button like 4 times?! My Outback Link to comment Share on other sites More sharing options...
Heytiggr Posted January 16, 2008 Author Share Posted January 16, 2008 OK totally not the subject of this thread. SO I take it no one knows how to disconnect the shade from the moonroof so it won't close like I described earlier? Link to comment Share on other sites More sharing options...
Bimmer Posted January 22, 2008 Share Posted January 22, 2008 Hey Tigger, Why don't you figure it out and enlighten all of us? There's got to be just some little spring-loaded tab in there. I'd like to fix this, too... Ben Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 22, 2008 Share Posted January 22, 2008 I think Bimmer has the answer... I sure if you search through subarus tech sight for a replacement shade, it will have downloadable instructions on how to remove the shade. From there just figure out how the latch works and disable it. Most likely it's something simple like a spring loaded catch that allows it to push the shade all the back also, but then latches and pulls it closed too. You could do a little preliminary check first.... can you for example put the roof ALLLL the way back, close it partially and then slide the shade back again, if not I'm guessing the latch releases on full close. Go for it.... I don't have an OB but I LOVE your moonroofs!!! I borrowed one one day from the dealer and thought it was HUGE... of course this problem would annoy me too Link to comment Share on other sites More sharing options...
Heytiggr Posted January 22, 2008 Author Share Posted January 22, 2008 Looks like that's what I am going to have to do. I'll be back in when I get to it.... Link to comment Share on other sites More sharing options...
Evan Posted June 10, 2008 Share Posted June 10, 2008 Any luck with this? Link to comment Share on other sites More sharing options...
Madjik_Man Posted June 11, 2008 Share Posted June 11, 2008 There are two arms - one on each track - that grab the shade when opening and closing the moonroof. I found this out because one of my arms broke (no idea how). But with even just one arm disconnected, so to speak, I had full control of the shade. I loved it. So much better. Of course the arm rattled like hell in the track when driving so I had it fixed and am back to hating the fact the shade closes with the glass. Also another PIMA is the fact that when the glass is opening, the shade overlaps the glass by about 1-1.5" - meaning the shade is exposed to the elements by being 1-1.5" closer to the windshield than the leading edge of the glass. What the hell? Link to comment Share on other sites More sharing options...
NSFW Posted June 13, 2008 Share Posted June 13, 2008 Anyone know how hard it would be to remove the shade entirely? Since tinting my sunroof I never use it and would be glad to be rid of it. Link to comment Share on other sites More sharing options...
Hugo L. Posted June 13, 2008 Share Posted June 13, 2008 I would also like to be able to determine how much I open/close the moonroof, as opposed to predetermined «stops» from the factory. Oh, and my shade closes itself 3-4 inches upon hard braking. Link to comment Share on other sites More sharing options...
CTATV Posted June 17, 2008 Share Posted June 17, 2008 i dont think mine does tham... it a wagon thing? ill have to go try it in my car Link to comment Share on other sites More sharing options...
