VSS interchange between years?
Twyzted
I recently swapped a 5MT from a 98 OB 2.5 into my 99 L 2.2. The 98 used a 2 wire Vehicle Speed Sensor while the 99 uses a 3 wire VSS. Can I swap the 3 wire sensor in place of the 2 wire sensor? Even if it fits, will the new sensor function correctly? If not, is it possible to use the old sensor and have it work in my car? The biggest difference between the 2 vehicle is the 98 OB donor car was a MAF, while my 99 is a MAP car.
