Rockets GT Posted February 19, 2007 Share Posted February 19, 2007 I was at the dealership getting the plastic cover under the engine buttoned back up and I noticed that my two front tires are quite a bit more worn that the back two tires, almost to the point where I think I may need to replace them. My question is, how concerned should I be about having tires that are worn unevenly? Secondly, is this due to not rotating them enough? Thanks in advance. Rick Link to comment Share on other sites More sharing options...
vet Posted February 20, 2007 Share Posted February 20, 2007 I don't think fronts wearing faster than rears is a concern as long as they're even across the width of the tread. Fronts usually wear faster than rear. Link to comment Share on other sites More sharing options...
Scotty Posted February 20, 2007 Share Posted February 20, 2007 That's why you rotate them at 7500 miles. Link to comment Share on other sites More sharing options...
bergs Posted February 20, 2007 Share Posted February 20, 2007 That's why you rotate them at 7500 miles. Holy crap! I do mine every 5000..... Link to comment Share on other sites More sharing options...
ssekien Posted February 21, 2007 Share Posted February 21, 2007 I've gotten into the habit of rotating the tires every oil change. As for the original question, your tires are supposed to be within a certain circumference of each other or your diffs won't like it. Thread covering topic: http://legacygt.com/forums/showthread.php?t=12069&highlight=tire+circumference Link to comment Share on other sites More sharing options...
