Selim1968 Posted October 1, 2012 Share Posted October 1, 2012 I have an legacy L 90, m/t 2.2 engine, and the engine with no reason stall, and dont start again if the check engine is not on on the dash. The fuel sistem dont send gas to the inyectors, and the coil dont send power to the sparg plugs, some times the check engine come on again on the dash and the engine star with out a problem, but if the ligth in not on, there is no way to start the engine.:mad: I try the fuses en the kik panel, and onder de hood, I replace the coil, and test the fuel pump, and everithing is ok, I dont know what else to do. Link to comment Share on other sites More sharing options...
ehsnils Posted October 1, 2012 Share Posted October 1, 2012 Start with trying to read codes when you have the Check Engine light as described here: http://legacygt.com/forums/showthread.php/reading-obd-codes-146240.html That may tell you what's wrong. A guess from my part is that it's a sensor (Crank or Cam) or connector that's bad. Link to comment Share on other sites More sharing options...
Selim1968 Posted October 2, 2012 Author Share Posted October 2, 2012 Tanks I will, try Link to comment Share on other sites More sharing options...
enzotheracer Posted October 8, 2012 Share Posted October 8, 2012 if it was the cam sensor it would still run. buddy of mine has a 94 with a gen 1 body and has a bad cam sensor and it still starts. does the engine turn over when you try to start it? Link to comment Share on other sites More sharing options...
Selim1968 Posted October 15, 2012 Author Share Posted October 15, 2012 Yes, the engine turn over, but it dont send power to the plugs, or gas to the sistem, at this moment I´m saving money to send it to the dealer, but here in Costa Rica it,s a little bit expensive to do that. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 15, 2012 Share Posted October 15, 2012 Did you pull the codes yet? It will be a big help to us if you can. http://www.surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
