06wrxlbart Posted January 11, 2011 Share Posted January 11, 2011 What do I need to make the suspension like outback? I know I would need thicker tires and what else are the struts different ? Will I run into problems if I go for the outback look/ suspension? Link to comment Share on other sites More sharing options...
jagcars26 Posted January 11, 2011 Share Posted January 11, 2011 :lol: this is a trick question ,correct? Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 11, 2011 Share Posted January 11, 2011 Sell the LGT Wagon on here (TONS of people want them) then take the money and buy an OBXT, probably while making a profit. Save yourself the headaches and troubles of swapping suspensions, to get the same car. Heck, you could probably get a few OBXT owners to swap you outright..... it seems many want to lower theirs. Link to comment Share on other sites More sharing options...
06wrxlbart Posted January 11, 2011 Author Share Posted January 11, 2011 :lol: this is a trick question ,correct? No its not a trick question im just done with lowered cars. Link to comment Share on other sites More sharing options...
06wrxlbart Posted January 11, 2011 Author Share Posted January 11, 2011 Sell the LGT Wagon on here (TONS of people want them) then take the money and buy an OBXT, probably while making a pr ofit. Save yourself the headaches and troubles of swapping suspensions, to get the same car. Heck, you could probably get a few OBXT owners to swap you outright..... it seems many want to lower theirs. Trying to do swap but not many are willing to i think. Ill even swap for a 2.5i since its her car. Link to comment Share on other sites More sharing options...
frank_ster Posted January 11, 2011 Share Posted January 11, 2011 one of my many projects is little hydraulic cylinders doughnut shaped that would fit in with the springs so you could lift your car 1 2 3 or 4" any time .. i so need to quit my job ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
brilliant sleeper Posted January 11, 2011 Share Posted January 11, 2011 Sell the LGT Wagon on here (TONS of people want them) then take the money and buy an OBXT, probably while making a profit. Save yourself the headaches and troubles of swapping suspensions, to get the same car. Heck, you could probably get a few OBXT owners to swap you outright..... it seems many want to lower theirs. ^ this.. unless you're dead set on the current wagon Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 12, 2011 Share Posted January 12, 2011 Frank_ster, I would be willing to prototype those for you! I thought of something like that a few years back, I unforunately don't have the resources to mock one up..... Link to comment Share on other sites More sharing options...
Instanced Posted January 12, 2011 Share Posted January 12, 2011 heh it's already been done Frank_ster... I believe they call it... Air-ride... it's lighter then hydraulic systems too! Link to comment Share on other sites More sharing options...
jagcars26 Posted January 12, 2011 Share Posted January 12, 2011 No its not a trick question im just done with lowered cars. Buyers remorse Link to comment Share on other sites More sharing options...
snow05gtRI Posted January 13, 2011 Share Posted January 13, 2011 its more than just shocks/struts/springs. i sorta looked into lifting my GT sedan for the winter. theres some body spacers and i think the arms are different... didn't seem to be a direct swap Link to comment Share on other sites More sharing options...
citka Posted January 13, 2011 Share Posted January 13, 2011 Funny, I'm swapping out my OBXT suspension for Legacy GT swift springs and tokico's so I can get it down to lowerd LGT level. The OB shocks are taller than the LGT and the bump stops are taller as well. You could swap the shock/spring setup directly in and then get the OB bumpstops to top it all off. Link to comment Share on other sites More sharing options...
frank_ster Posted January 13, 2011 Share Posted January 13, 2011 heh it's already been done Frank_ster... I believe they call it... Air-ride... it's lighter then hydraulic systems too! yea ? where u gonna put it ! i have seen the air strut conversion .. but they completely remouve the shock part .. so its only for show .. remember this is a macpherson strut not a chevy pickup. with my doughnut cylinder. ( witch may be air actuated ) will only increase preload of the spring and not change the rate. so will effectivly raise your car with out making it ride like a truck. you show me a air ride system that will fit on my car and not make the car a peice of shit and i will buy it instantly .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
06wrxlbart Posted January 14, 2011 Author Share Posted January 14, 2011 Im going to throw on the oem suspension once the weather warms up. Link to comment Share on other sites More sharing options...
frank_ster Posted January 14, 2011 Share Posted January 14, 2011 i'm sure the longer strut assemblys and a wheel alignement will be enough Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
define Posted January 14, 2011 Share Posted January 14, 2011 OBXT to Legacy suspension I understand... I'm considering it now. But the other direction? Have you ever felt stock OBXT suspension? It is a boat, and there isn't a lot of aftermarket support to help fix it. Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 14, 2011 Share Posted January 14, 2011 OBXT to Legacy suspension I understand... I'm considering it now. But the other direction? Have you ever felt stock OBXT suspension? It is a boat, and there isn't a lot of aftermarket support to help fix it. hmmm.... maybe you could make a trip to visit the OP and you two could swap titles.... not as interesting as a wife swap, but it seems like you each want some of that greener grass on the other side Link to comment Share on other sites More sharing options...
