Kaeser 2.5i Posted August 2, 2009 Share Posted August 2, 2009 Can you guys take a look at my logs? I may be missing a parameter or two, but in the first log, you can see where FBKC picked up some knock. In the second and third log, the Knock Sum seems pretty high, but nothing in the FBKC. What do you recommend I change on this? The logs were taken at about 90 deg F. The car feels a good bit slower than it did when I first installed the map The car is a 05 LGT 5EAT with Borla Catback and transmission cooler, the rest of it is stock. Thanks for the help! Link to comment Share on other sites More sharing options...
biz77 Posted August 3, 2009 Share Posted August 3, 2009 Do a learning view to check IAM and FLKC. To check for knock I'd log only the following for best resolution: RPM Throttle plate Load Total timing Knock sum Check Learning view before and after pull. Logs #2 and #3 look okay. What you need to look for with knock sum is incrementing while doing a full-throttle pull, which it doesn't seem to be doing. Link to comment Share on other sites More sharing options...
