urdrwho Posted November 17, 2013 Share Posted November 17, 2013 While trying to deceipher the ever ongoing debate over trans fluids to use in our Volvo that has the Aisin transmission, I saw someone mention Lubegard. So I went searching to find out about Lubegard and I found a link where they mention Subaru 4WD. What's the scoop on this high friction modifier; has anyone used it in a Subbie? Do some subbie transmissions need HFM fluids? http://www.autocarepro.com/Article/42016/lubegard_products_receive_more_automaker_endorsements.aspx "“Subaru of Switzerland, in an official technical service bulletin, recently recommended LUBEGARD Highly Friction Modified ATF Supplement (our black bottle), as a solution to reduce customers complaints of noise and/or chatter in the 4WD clutch of automatic transmissions.” Link to comment Share on other sites More sharing options...
Kevlar_07 Posted November 20, 2013 Share Posted November 20, 2013 sounds good on paper, I have a slight torque bind issue with my 96 I'm tempted to give this a try if a fluid flush doesn't do the trick Link to comment Share on other sites More sharing options...
zedhead Posted November 23, 2013 Share Posted November 23, 2013 I've been using lubegard for years. Best tranny additive available. Link to comment Share on other sites More sharing options...
Kevlar_07 Posted November 24, 2013 Share Posted November 24, 2013 I've been using lubegard for years. Best tranny additive available. Do you use the red or black bottle? Link to comment Share on other sites More sharing options...
urdrwho Posted November 25, 2013 Author Share Posted November 25, 2013 I also wonder? The black bottle has high friction modifiers. I went to the link I originally posted and it had -- “Subaru of Switzerland, in an official technical service bulletin, recently recommended LUBEGARD Highly Friction Modified ATF Supplement (our black bottle), as a solution to reduce customers complaints of noise and/or chatter in the 4WD clutch of automatic transmissions.” Chart for their products http://www.lubegard.com/pdfs/2010_LUBEGARD_CC_FINAL.pdf Do I get her if I buy Lubeguard product? http://www.lubegard.com/Glossamer.aspx Do you use the red or black bottle? Link to comment Share on other sites More sharing options...
