RHDsubaru Posted December 29, 2016 Share Posted December 29, 2016 replaced rear oil seal,notice oil leking around two plates on the back of motor 2.2 legacy L wagon 1993. replaced rear main seal does not leak at idle but looks like its is raining at 2500 rpms. I am confused help if possible.. Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 29, 2016 Share Posted December 29, 2016 oil separator plate perhaps. Link to comment Share on other sites More sharing options...
RHDsubaru Posted December 30, 2016 Author Share Posted December 30, 2016 iIf it is oil seperator plate how do I seal or fix. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 5, 2017 Share Posted January 5, 2017 Depends if you have a metal or plastic one. The plastic one warps-replace with metal one. The metal one will need to be resealed. It's located behind the flywheel/flexplate Link to comment Share on other sites More sharing options...
wtdash Posted January 5, 2017 Share Posted January 5, 2017 The REAR Main Seal can be a 'challenge' to install correctly. In too far - it leaks; not far enough-it leaks. since it's coming back out anyway, check for leaks arount that sep. plate. Yours should be metal, as they went plastic around '96-'00 and back to aluminum. This LINK shows the plastic one but resealing your metal one is the same. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 5, 2017 Share Posted January 5, 2017 The link says his oil pan was leaking another good thing to check for. Link to comment Share on other sites More sharing options...
