I Wish Posted December 10, 2010 Share Posted December 10, 2010 If I do not lock the reverse lockout cam under the car. Can I still install a short shift if I can still pull the cable up through the lever? I was thinking about using some fishing line or some other cable to pull the reverse cable up. My car is pretty low and I do not ahve ramps or access to a hoist this weekend. Link to comment Share on other sites More sharing options...
Zimm Posted December 11, 2010 Share Posted December 11, 2010 It won't work. The lockout is spring loaded and if you don't lock it in place it will retract the cable a bit and you won't be able to get the roll pin to line up. Link to comment Share on other sites More sharing options...
I Wish Posted December 11, 2010 Author Share Posted December 11, 2010 I have the Mode racing double adjustable lever and it looks like I have a good 60mm if I put the lever in it's lowest position. Is that enough? Link to comment Share on other sites More sharing options...
Zimm Posted December 11, 2010 Share Posted December 11, 2010 Not sure, I installed the kartboy shifter and I definitely needed to do it. It was not adjustable. I guess the big thing is that if you can get it to work you can't put the stocker back on. Then you are SOL with a car you can't drive. Link to comment Share on other sites More sharing options...
