DavidAlphin Posted February 16, 2015 Share Posted February 16, 2015 I'm looking to install a couple of gauge for my 96LGT. I'm wanting to install an oil pressure and oil temp gauge. I'm looking for some insight as to what gauges/kits you guys ran and where you tapped into the motor to do so... Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 18, 2015 Share Posted February 18, 2015 Killer B has an oil pan drain fitting that you can use the tap the pan for temp. Most people use the oil galley for the pressure. Subaru sells a oil galley plug designed for this. Link to comment Share on other sites More sharing options...
ras06LGT Posted February 18, 2015 Share Posted February 18, 2015 The gallery I've tapped into is where the stock pressure switch is located (at least for the 06 Legacy). Unless racing I don't see a need for oil temp on a daily driver. I gauge when the oil is up to temp by the pressure seen at idle. Once it drops to around 30 psi at idle I know things are up to operating condition. The coolant gets up to temp well before this. Link to comment Share on other sites More sharing options...
